Powermatic Model 93 15" Scroll Saw
« back to Scrollsawing forum
Forum topic by NikkiLaRue posted 05-30-2014 12:48 PM 6730 views 0 times favorited 10 replies Add to Favorites Watch
View NikkiLaRue's profile
NikkiLaRue
296 posts in 1687 days
05-30-2014 12:48 PM
Topic tags/keywords: scroll saw question
I ran across a Powermatic Model 93 15” Scroll Saw at a yard sale yesterday for $20. I’ve never owned or even used a scroll saw before. It seems to run just fine, but doesn’t have blade in it. It had about half of a blade still hooked in the lower arm. One thing I would like to know is how the blade hooks in the upper arm. There is just a v slot on the upper arm…..there is a spring loaded set screw with a black knob above the v slot, but it isn’t long enough to tighten down on the blade…..is there a piece missing?
10 replies so far
View mahdee's profile
mahdee
4025 posts in 1972 days
#1 posted 05-30-2014 01:38 PM
No. Sounds like nothing is missing and you got a good deal. Maybe post a picture of it so someone can explain how to hook the blade. The knob on top adjusts the tension.
-- earthartandfoods.com
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2574 days
#2 posted 05-30-2014 01:49 PM
Congratulations on a nice find at a great price. I wish I could find yard sales like that, all the ones I stop at usually only offer junk, crap, or garbage.
View  woodshaver Tony C   's profile
woodshaver Tony C
6231 posts in 3557 days
#3 posted 05-30-2014 03:07 PM
I don’t own a scroll saw but for 20 bucks I might. What a good deal! Hope you get that blade problem worked out so you can have some fun with it. Good luck!
Tony
-- St Augustine FL, Experience is the sum of our mistakes!
View Loren's profile
10477 posts in 3852 days
#4 posted 05-30-2014 03:28 PM
You may have a rare machine. I’ve never seen a picture of a small
Powermatic scroll saw.
This is a site that documents vintage machinery. It would be
kind of you to upload a picture to it of your saw… or if you
post one here I’ll do it.
http://vintagemachinery.org/mfgindex/detail.aspx?id=655&tab=4
View DocSavage45's profile
DocSavage45
8725 posts in 3047 days
#5 posted 05-30-2014 04:28 PM
Nikki,
Hope you have good luck with the saw. I’m just learning about scroll saws as I bought one on craig’s list and the clamping mechanism is screwed up. There are 5 inch and 6 inch blades. Pin and Pinless.
Found a manual if you don’t have one. It’s 15 bucks on eBay. LOL!
You can use YouTube to become familiar as most scroll saws have the same basic mechanisms.
Good Luck,
Tom
-- Cau Haus Designs, Thomas J. Tieffenbacher
NikkiLaRue
#6 posted 05-30-2014 05:43 PM
More pics here at my photobucket….... http://s1274.photobucket.com/user/smokinnikki/library/Tools
View Planeman40's profile
Planeman40
1309 posts in 2965 days
#7 posted 05-30-2014 06:01 PM
Curiosity drove me to do a Google search on “Powermatic Model 93 15” Scroll Saw” as Powermatic is a major light industrial power woodworking brand and $20 for one of their machines would have been the steal of the year! I came up with the user’s manual for a Chinese made scroll saw exactly like the one I have had for a number of years. Yes, there are TWO Powermatic brand scroll saws!
Anyway, my little scroll saw is exactly like yours but doesn’t have the “Powermatic” name. Just to let you know, it is quite a capable little scroll saw. I love mine. One word of advice. All scroll saws vibrate like crazy due to all of the reciprocal moving parts. Bolt it down to a sturdy table or using it will be an annoyance.
Oh, and to answer your question about how to hook up the blade. This saw takes “pin-type” scroll saw blades. these blades have a small round pin at 90 degrees to the blade at each end of the blade. Just slide the blade through the little slot and rest the pin atop the slot. Same for the lower end. And, yes, you are missing a part. This is a separate piece that adapts pinless blades to the saw. I have that piece and can assure you you aren’t missing anything worthwhile. It is so cumbersome to use that after trying it once I tossed it into a box and have never used it since. Just use pin-type blades and all will be fine. And the screw thing with the plastic knob above the pin-type blade is for use with the pinless blade holder. I never could figure out how, but since I don’t use pinless blades I don’t give it much thought. Here is the link to the user’s manual: http://www.ebay.com/itm/POWERMATIC-93-15-Scroll-Saw-Operator-Part-Manual-0540-/290691873358 You really don’t need it though.
Have fun,
Planeman
View Woodmaster1's profile
Woodmaster1
1073 posts in 2791 days
#8 posted 05-30-2014 07:28 PM
The part you are missing is used by several brands made just like that saw. I have a delta scroll saw just like it.
View Jim Finn's profile
Jim Finn
2687 posts in 3126 days
#9 posted 05-30-2014 09:59 PM
I work with my scroll saws most every day. I have two Hegners and one Old 15” Jet similar to yours. (Single speed) I got mine for $15 last year and it works great. Yours is a good saw, Looks like it has an induction motor I think. If it is variable speed it is not an induction motor. (No brushes on an induction motor). Long lasting motor. Looks like you have a blade clamp missing on the top arm. The top and bottom blade clamps are the same. The screw on top will hold the upper blade clamp in place. You need pinless blades. (A good thing). The blades at the local building supply store are lousy and expensive. I suggest you get blades from http://www.mikesworkshop.com/blades.htm. Great service and good prices. Excellent blades. He will give you advice on what blade to buy. A knowledgeable guy. I do not know if you can buy a blade clamp for your saw and you need one. I have some I will send you that look like they will fit your saw. I changed my Jet blade clamps to Hegner clamps and they work on it just fine. You have a good little saw there and the first thing I would do is take off that orange wood hold down and leave it off. Most all of us that use scroll saws a lot remove them. Email me and I will send you some blade clamps and answer any questions you may have about working with a scroll saw.
-- No PHD just a DD214 Website> craftingcouple.com
Planeman40
#10 posted 05-30-2014 11:10 PM
Thanks Jim for the post. Yes, that Hegner blade holder looks like it should work. It still looks like a cumbersome process to do blade changes, particularly when making numerous un-attach and re-attach of the top of the blade when doing marquetry or intricate projects. And some searching on the web finally suggested to me what that knob screw thingy at the top blade location might be for and that is to keep the top blade holder from flying through the air if the blade breaks! After looking at some web sites, the Hegner-type blade holder sells for around $20 each and you need two of them. For $40 I think I will stick for pin-type blades.
All of this tells me there is an unmet need for an inexpensive quick change, precise blade holder for these machines. Someone out there should get to work on this.
Planeman
