My Bandsaw is Smoking!!!!!
Forum topic by ptkaster posted 05-29-2014 04:51 PM 1269 views 0 times favorited 13 replies Add to Favorites Watch
View ptkaster's profile
36 posts in 2046 days
05-29-2014 04:51 PM
Topic tags/keywords: bandsaw rikon 10-325 rikon 10-325 smoking smells help
I have a Rikon 10-325 and I must admit that so far it has been a pretty good machine. I use it infrequently, but whn I do I am cutting 12” logs, which seems to be taking its toll. When I mount my new blade and tension it, the wheel is incredibly hard to turn. Not impossible, but it seems like it should be easier. I can hear a noise that sounds like something is scraping when I turn it. I have looked EVERYWHERE around the blade and I have yet to find and obstruction. When I turn it on, I can smell something that smells like not like wood smoke but a different more oily smoke. I cant see the smoke, but I can certainely smell it. My only though is that the bearing might be smoking from overtension. I do tighten my blades pretty hard. Do you think that’s the problem? Please give all advice and experience. Thanks,
13 replies so far
View ajosephg's profile
1880 posts in 3490 days
#1 posted 05-29-2014 04:57 PM
Not familar with that saw but I’d look at the belt/s and pulleys to see if they are misaligned. If they are fine, then remove the belt and see if the wheels rotate freely and go from there.
-- Joe
View NiteWalker's profile
2736 posts in 2506 days
#2 posted 05-29-2014 04:59 PM
Check the bearings on the wheels.
One of them may have seized up.
View mahdee's profile
3849 posts in 1696 days
#3 posted 05-29-2014 05:02 PM
Sounds like a broken ball inside the bearing.
View bondogaposis's profile
4629 posts in 2280 days
#4 posted 05-29-2014 05:11 PM
Maybe the belt is slipping on the pulley, check there first, then start looking at bearings.
-- Bondo Gaposis
View JAAune's profile
1780 posts in 2246 days
#5 posted 05-29-2014 05:22 PM
Take the blade off and check how smooth the wheel rotates. If it’s good then check the belt. The process of eliminating variables helps troubleshooting a lot.
Also, if you’re applying that much tension to the blades then you’re compensating for some error in your bandsaw setup. Either your guide blocks aren’t set right or you have a bad/dull blade. There just isn’t a need for excessive tension and you’ll either damage the bearings, flex the saw frame or gouge up the rubber tires if you overdo it.
-- See my work at and
#6 posted 05-29-2014 05:52 PM
Thanks all for the responses! I figured out that the top wheel was grinding on the blade guard when it was raised fully. I believe it is because the wheel was tilted from blade tracking alignment. Off to work to solve the problem. Thanks!
View MrKnowItAll's profile
20 posts in 1404 days
#7 posted 05-29-2014 06:10 PM
WalMart sells some nice little patches that worked well for me.
-- -because I said so, that's why
View b2rtch's profile
4851 posts in 2977 days
#8 posted 05-29-2014 06:22 PM
“WalMart sells some nice little patches that worked well for me.”???????????
-- Bert
View SCOTSMAN's profile
5851 posts in 3514 days
#9 posted 05-29-2014 06:22 PM
Are you sure the blade is sharp ? and everything is set up properly? It does sound by the smell you talk about like a bearing problem. Alistair
View Andy Ponder's profile
Andy Ponder
237 posts in 1637 days
#10 posted 05-29-2014 08:40 PM
@MrKnowItAll…..The patches do work better than the gum, but taste a lot worse.
-- AP--I thought growing old would take longer.
#11 posted 05-29-2014 09:09 PM
Yeah, that happens, I ground the corner off of mine, so it can’t hit the wheel.
-- Bondo Gaposis
View Surfside's profile
3389 posts in 2102 days
#12 posted 05-29-2014 09:25 PM
It could be just too much friction between some parts of the band saw.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View WhyMe's profile
991 posts in 1490 days
#13 posted 05-29-2014 09:58 PM
ptkaster, when you say you tighten the blade pretty hard. Do you not tighten the blade by the tension gauge?
