What plywood to use?
Forum topic by Notw posted 05-29-2014 03:52 PM 1954 views 0 times favorited 27 replies Add to Favorites Watch
View Notw's profile
Notw
661 posts in 1839 days
05-29-2014 03:52 PM
I am about to build two nightstands (small dressers really) and my wife would like them painted black as opposed to staining. I wouldn’t image I would need a veneer faced plywood to build these since they are just going to be covered in paint in the end. My question is will I be able to use a BC grade plywood and sand the outside facing pieces with an orbital sander to achieve a smooth paintable surface? Any suggestions or tips are appreciated. Thanks
27 replies so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2455 days
#1 posted 05-29-2014 04:06 PM
I did one project where I used the Home Depot BC plywood and painted it. I won’t do that again. The BC grading is a stretch, there will still be filling/sanding necessary, and if both sides will show, forget it. The purebond birch stiff they sell is much nicer and pretty smooth and ready to paint as-is. At $10 more expensive for a 4×8 3/4” sheet, it’s not worth the headache to deal with their BC. I also found their BC more prone to splintering on the cut than their purebond, probably due to the differing types of surface ply/veneer.
If you’re getting BC from another source that has better quality, well, I can’t speak to that. For a painted project, $45/sheet for something that’s ready to go is good for me.
Either way, prime it before painting. I used Kilz original on that BC plywood and it sucked it up.
Edit : Now that I think back, that BC pine ply from HD also warped quite a bit once I cut it down.
View NiteWalker's profile
NiteWalker
2737 posts in 2663 days
#2 posted 05-29-2014 04:24 PM
The purebond plywood is great. That’s what I would use.
View JAAune's profile
JAAune
1825 posts in 2402 days
#3 posted 05-29-2014 05:15 PM
MDO would probably make your life easier. Priming and sanding constructiong grade plywood to get a good painting surface can be a hassle. I’ve done it on shop fixtures and it works but the finish wasn’t furniture grade.
View bondogaposis's profile
bondogaposis
4899 posts in 2437 days
#4 posted 05-29-2014 05:15 PM
I’d think about using MDF if you are going to paint it.
-- Bondo Gaposis
View ColonelTravis's profile
ColonelTravis
1856 posts in 1980 days
#5 posted 05-29-2014 05:46 PM
Agree with the others – stay away from BC from the big stores if you’re doing this. It’s fine for, say, a back room closet shelf that almost no one sees, but I wouldn’t use it for furniture. Agree that sanding that would be a total waste of your time, considering the nicer grades you can get from a lumber store, if you have one nearby. It’s more expensive but it’s much nicer.
Is hardwood absolutely out of the question for these?
View Earlextech's profile
Earlextech
1162 posts in 2776 days
#6 posted 05-29-2014 05:47 PM
Birch plywood at Lowes – http://www.lowes.com/pd_37985-99899-37985_0__?productId=3658234&Ntt=birch+plywood&pl=1&currentURL=%3FNtt%3Dbirch%2Bplywood&facetInfo=
No BC for furniture.
View Yonak's profile
Yonak
986 posts in 1607 days
#7 posted 05-29-2014 05:55 PM
+1 for MDF. It provides a superior painting surface, unless it clashes with the texture of the frame wood. By the way, what kind of wood do you plan to use for the frame ?
BinghamtonEd
#8 posted 05-29-2014 05:59 PM
I don’t know if it’s an option, but I would consider dying/staining it, to let the wood grain show through a bit.
View MrKnowItAll's profile
MrKnowItAll
20 posts in 1560 days
#9 posted 05-29-2014 06:08 PM
I exclusively use OSB for my finer furniture projects. The 5/8 of course…..7/16 would be ridiculous.
Since the edges are already painted, I go ahead and paint the rest of the project to match.
-- -because I said so, that's why
View MT_Stringer's profile
MT_Stringer
3173 posts in 3317 days
#10 posted 05-29-2014 06:18 PM
Mom's Kitchen Cabinets
Poplar face frame, drawers and drawer fronts.
MDF panels for the drawer fronts.
Primed first, then painted with Benjamin Moore Impervo Satin
Bench with three cubbies
Details about stain included in the description
My friend loves them.
Good luck.
Mike
NiteWalker
#11 posted 05-29-2014 07:09 PM
I would NOT use mdf for the main structure.
I made a small painted bookcase out of mdf years ago and it just doesn’t hold up.
No more for me.
View TheFridge's profile
TheFridge
9879 posts in 1572 days
#12 posted 05-29-2014 07:26 PM
Anyone ever use the “sandeply” brand from Home Depot?
BinghamtonEd
#13 posted 05-29-2014 07:31 PM
I did once, and it worked just fine, however finding it there was a fluke. It was there, out of the blue, one week, gone the next, never to be seen again. However the HD that’s about 30mi away stocks it regularly.
View waho6o9's profile
waho6o9
8295 posts in 2663 days
#14 posted 05-29-2014 07:31 PM
MDO is what I would use.
It paints up real nice.
View ChefHDAN's profile
ChefHDAN
1098 posts in 2935 days
#15 posted 05-29-2014 07:48 PM
+1 for the MDO, I just finished a project with MDF, and I’ll never do another, between the dust, the weight and the edge finishes, it’s not worth it. MDF used to be really cheap, but it’s gotten more expensive and the added time to futz with the edges makes way to time consuming.
