Solvent for PVA glue on concrete floor?
Forum topic by BTKS posted 05-29-2014 02:55 AM 1469 views 0 times favorited 11 replies Add to Favorites Watch
View BTKS's profile
BTKS
1986 posts in 3459 days
05-29-2014 02:55 AM
I have an assembly table in my shop and the floor around the perimeter is really slick!
I guess it is the dripped glue smeared around before it dries. Every now and then, I scrap the floor with a paint scraper and that helps. Even after a harsh scraping it is not like the rest of the floor.
The concrete is about seven years old and sealed with an acrylic sealer. The glue I’ve been dripping is PVA, specifically Titebond III exterior glue.
Is there anything that will dissolve the glue without ruining the sealed finish?
Thanks in advance for any help you all might give me.
BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
11 replies so far
View Yonak's profile
Yonak
986 posts in 1516 days
#1 posted 05-29-2014 03:48 AM
The MSDS lists ethanol as the solvent / carrier so I would say alchohol would be a good try. I can’t say if alcohol would attack the acrylic but I would guess it would. You may have to decide if you’d rather live with the glue or re-apply the acrylic. Please report back with results or if you found another solution.
View Knothead62's profile
Knothead62
2584 posts in 2956 days
#2 posted 05-29-2014 10:04 AM
Try 91% isopropyl alcohol (high power rubbing alcohol) as it’s real cheap. Or denatured alcohol which is more expensive. I use both for cleaning epoxy off custom fishing rods.
View robscastle's profile
robscastle
4967 posts in 2199 days
#3 posted 05-29-2014 10:26 AM
Are you sure the assembly table is in fact in your workshop or not maybe somewhere else?
I just checked out your workshop to take a peek at your assembly table and you don’t have one! very strange?
Sure its not solvent base glue you are using?
-- Regards Robert
View JAAune's profile
JAAune
1797 posts in 2311 days
#4 posted 05-29-2014 03:38 PM
Hot vinegar works pretty well to soften PVA. It will usually start peeling after being exposed for a little while.
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#5 posted 05-29-2014 04:25 PM
That is weird, my Titebond glue pops off concrete floors easily with a scraper. You could hit it with a pole sander (like one used to sand sheetrock) to rough it up.
View rrww's profile
rrww
263 posts in 2108 days
#6 posted 05-29-2014 06:50 PM
I have epoxy floors and my experience is the same as Pinto with Titebond
robscastle
#7 posted 05-30-2014 04:21 PM
Yep a scraper fixes up my floor too
-- Regards Robert
View bandit571's profile
bandit571
19965 posts in 2678 days
#8 posted 05-30-2014 04:29 PM
Place some old newspapers down BEFORE the assembly work begins. Afterwards, just pick up the papers. A daily news type of paper. What, maybe $0.50 a day? Lay it around where the glue does drip, to catch the excessive glue.
Yonak
#9 posted 05-31-2014 02:59 AM
Re : Laying down newspapers.
I get lots of sheets of corrugated with shipments, which I use to protect the floor in the paint room. The advantage is it can stay down for awhile before being kicked up as newspapers are.
View BTKS's profile
BTKS
#10 posted 06-04-2014 03:48 AM
Thanks guys,
I won’t be able to check these suggestions for a couple of days but I can’t wait.
The pole sander followed by some vinegar sounds like my first try. I keep both 90+ rubbing alcohol and vinegar around for cleaning and rust removal.
Thanks again.
BTKS
View BTKS's profile
BTKS
#11 posted 06-04-2014 03:51 AM
Robert,
Yes the table is there, at least it was an hour ago. I decided to post my shop but not the contents. I did not want to display a shopping list for local thieves.
I do believe there is a vanishing solution somewhere in the shop. I can’t find half the things I need when I need them. I trip over them when I don’t need them.
Later,
BTKS
