Water-based poly over India ink?
Forum topic by SuperCubber posted 05-28-2014 05:21 PM 1244 views 0 times favorited 5 replies Add to Favorites Watch
View SuperCubber's profile
SuperCubber
1026 posts in 2283 days
05-28-2014 05:21 PM
Hey guys,
I’m using India ink for the first time. Does anyone know whether or not I can use water-based poly over it? The bottle says it contains shellac.
Thanks,
Joe
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
5 replies so far
View rrww's profile
rrww
263 posts in 2112 days
#1 posted 05-28-2014 06:07 PM
I would use a coat of seal coat over the ink, then finish with whatever you like.
View Clint Searl's profile
Clint Searl
1533 posts in 2360 days
#2 posted 05-28-2014 07:30 PM
Only if you seal it with 3 coats of BLO.
View dawsonbob's profile
dawsonbob
2856 posts in 1754 days
#3 posted 05-28-2014 11:54 PM
Zinzer Seal Coat should do the job. You can put virtually any finish over that.
-- Mistakes are what pave the road to perfection
View Mark Kornell's profile
Mark Kornell
1169 posts in 2530 days
#4 posted 05-29-2014 12:19 AM
India ink usually contains some portion of shellac as a binder. Using shellac on top of that can be problematic as the fresh shellac can dissolve the ink somewhat and cause smearing.
WB poly directly on top of the ink is fine. If your intention is a high gloss finish, you’ll be better off spraying than brushing.
-- Mark Kornell, Kornell Wood Design
SuperCubber
#5 posted 05-29-2014 01:30 AM
Thanks for the replies, guys! I’m not going for a high gloss, but I plan on spraying either way.
Thanks for all the advice. Hopefully the finished project will be posted this week.
