stack laminated turning question
« back to Woodturning forum
Forum topic by kmetzger posted 05-28-2014 02:08 PM 1164 views 0 times favorited 3 replies Add to Favorites Watch
View kmetzger's profile
kmetzger
157 posts in 2022 days
05-28-2014 02:08 PM
I’m looking into stack laminated turnings. Here’s a useful introduction: https://www.youtube.com/watch?v=K43v_ABjQIU
But what I’m wondering is whether grain direction is important when gluing boards together. I know that normally boards should not be glued cross-grain, but I can’t find anything discussing this topic.
-- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25
3 replies so far
View TheDane's profile
TheDane
5552 posts in 3867 days
#1 posted 05-28-2014 09:11 PM
Kim—- This is just a WAG, but I would think gluing with or across the grain wouldn’t be much of a problem depending on how thin you are going to make the walls. If you are not going to hollow (the guy in the video did not) then it might be an issue. Wood moves and you can’t stop it, but the more you remove from the inside of the object, the less movement there may be. Again, just an guess on my part.
View hairy's profile
hairy
2783 posts in 3736 days
#2 posted 05-29-2014 12:39 AM
Maybe this will help.
http://www.woodturningonline.com/Turning/Turning_projects.php?catid=60
-- My reality check bounced...
View Wildwood's profile
Wildwood
2481 posts in 2338 days
#3 posted 05-29-2014 10:35 AM
All the glue ups in the video are face grain to face grain hence laminated vase. When he turns that vase is turning both end and side grain at the same time.
If he orientated the top piece where grain running up & down, would need to turn a tenon on that top piece and drill a hole in base to accept that tenon. End grain to side grain glue up joints not very strong.
If he were making a segmented vase would have a combination of face and end grain glue ups. Strenght comes from the side to side gain joints.
Whenever turn a multi piece spindles or hollow forms always use tenon & hole glue ups for strength, always turn elements to hide or mask glue joints.
-- Bill
