Solid wood cabinet door with v grooves.
« back to LumberJocks.com Site Feedback forum
Forum topic by roofner posted 05-28-2014 02:02 AM 972 views 0 times favorited 4 replies Add to Favorites Watch
View roofner's profile
roofner
122 posts in 2305 days
05-28-2014 02:02 AM
Topic tags/keywords: question
What angle would you set your table saw to rip v groves about 1/4 inch deep? I have already built a case covered with beaded board and want to space the v groves about same distance apart as the beads . Doors will probably be made up of glued up pine boards. Normally you overlap the doors by 1/2 inch minus 1/8 between the 2 doors is that correct? These are my first doors I have built. Anyone built this style door and remember the angle used?
View Rick's profile
Rick
9698 posts in 3054 days
#1 posted 05-28-2014 02:13 AM
Might I suggest that you choose a different “Forum” IE: “Woodworking Skill Share” for your Question?
This is the “Site Feedback” Forum. Usually used by Members that have Questions, Concerns or Suggestions relating to the Operation of this site
Thank You.
-- LIFE is what happens when you're planning on doing Other Things!
View waho6o9's profile
waho6o9
8204 posts in 2599 days
#2 posted 05-28-2014 02:16 AM
How about a router bit with a 60 degree point on it?
roofner
#3 posted 05-29-2014 01:10 PM
Thanks for all your suggestions I changed my mind I bought a Freud 20-301 Radius V-Groove Router Bit for Freud’s 99-472 Beadboard Router Bit System, 1/4-Inch Shank. Waiting to receive bit.
View Rick's profile
Rick
#4 posted 05-30-2014 03:00 AM
OH! That’s good!
