Two Sketchup questions
Forum topic by rhybeka posted 05-26-2014 03:35 PM 1035 views 0 times favorited 8 replies Add to Favorites Watch
View rhybeka's profile
rhybeka
4294 posts in 3263 days
05-26-2014 03:35 PM
hey all :) I wasn’t quite sure where to put this so if Ms. Debbie needs to move it – please do so :) I’m in the process of building my next shop in Sketchup and am having two issues I just can’t seem to find answers for so I thought I’d ask. One is if anyone can tell me if the newest version (Sketchup Make/2014) has a plugin folder on Mac? I can’t even seem to locate a Sketchup folder in my App Support / Google folder structure but I have some .rb files I would like to try (HomeBuilder for example)
second question is – is there an easy way to make cutouts of studs? example – I’m trying to insert headers and footers for windows and need to cut pieces of my studs out. Drawing lines around the stud at the top and bottoms of the stud doesn’t seem to be working very well. Any other tools that could be used for this purpose? Any direction would be great! I’ve checked out a few Sketchup podcasts as well and nothing has really come close to answering either question. ah well- back to it!
-- Beka/Becky - aspiring jill of all trades, still learning to not read the directions.
8 replies so far
View NoThanks's profile
NoThanks
798 posts in 1671 days
#1 posted 05-26-2014 04:00 PM
Just draw 1 line at the top and 1 line at the bottom and use your push/pull tool to push the center of the stud away.
If you have made it a component, be sure to make it unique so that it doesn’t change all of them.
I can’t help with the Mac question.
-- Because I'm gone, that's why!
View JAAune's profile
JAAune
1837 posts in 2458 days
#2 posted 05-26-2014 04:39 PM
Since the 2014 version of Sketchup no longer keeps plugins within the program folder, it’s likely that it doesn’t create the folder in your user files until after you install one. I’d suggest downloading the desired plugin then loading Sketchup and going to Windows->preferences->install extension. Once you install one, it should create a plugin folder in the right location.
rhybeka
#3 posted 06-08-2014 05:31 PM
Hmmm -can’t install the extension cause it’s only an .rb file. Guess it hasn’t been updated to go with the latest version yet? and I’m also on a mac so it’s always interesting :D
JAAune
#4 posted 06-08-2014 06:47 PM
Sketchup can install .rbz through the installer. Find a plugin with the .rbz extenstion and install that to ensure the plugin folder is created. Then you can drop .rb files inside.
rhybeka
#5 posted 06-09-2014 01:59 AM
hm. still no luck after installing cut list from the extension library. i must be missing something still
JAAune
#6 posted 06-09-2014 02:31 AM
I think I know it now. You’re looking under the Google folder but using Sketchup2014. Trimble quit using the Google folder and you should look for a Sketchup2014 or Trimble folder instead.
In Windows it’s located in the hidden folders but Mac may be different.
View Mike Throckmorton's profile
Mike Throckmorton
124 posts in 1806 days
#7 posted 06-09-2014 02:40 AM
This link should help.
If you read down a bit, the info is there.
-- You are never complete, you just draw a line where done is and stop at that line.
rhybeka
#8 posted 06-10-2014 01:26 AM
hidden folders will always get me! still a newb when it comes to OS X – or they have a few too many folders named Library! Thanks Mike and JA!
