| Forum topic by ellen35 | posted 308 days ago | 1577 views | 2 times favorited | 32 replies | ![]() |
308 days ago |
Topic tags/keywords: maple saw burn I have several 6-8 foot maple boards that need about 1/2 inch ripped off. I know (from experience) that cutting maple can cause burns. Since I am a novice at this, I was wondering what, if any, the trick is to doing it without burning. These were expensive pieces and I really really need them nice and clean. The boards are a hail over 3/4” thick and 6-8 feet in length. -- Ellen on Cape Cod |
308 days ago |
I use a frued 24 tooth rip blade for most ripping operations. crosscut blades will generate heat and cause the burning you describe. A rip blade has a flat top chisel grinde that severs the fibers cleanly and bigger gullets to carry away the chips. cross cut and combo blades use an alternateing angled grind designed for cross cutting and have smaller gullets. make sure your fence is aligned to the blade and with a rip blade you can increase the feed rate which will cut down on burning also. -- hey honey! watch this! |
308 days ago |
Ellen, here is a picture of some cherry I recently ripped on my table saw. Cherry is notorious for burning, even more so than maple.
Some burn marks are simply inevitable when milling wood but this can be mitigated by (1) making sure that you have a SHARP premium blade in your saw. I use only Forrest blades (2) make sure that your blade and fence are aligned. With my Craftsman saw I occasionally spend up to 10 minutes aligning the fence and blade for each cut. With my fence the front and rear of the fence can end up being angled if you simply set the blade to fence distance and lock it down. Here is a picture of my saw and the “fine adjusting tool” that I use to align the fence:
And (3) did I mention use a SHARP premium blade. :) Hope this helps. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
308 days ago |
Buy a good rip blade. A crosscut blade will definitely burn, and based on my experiences with the blades that you already own, the heat generated can cause the teeth to become suddenly independent of the blade. I would suggest going to www.royceayr.com I have some blades from them that are 25+ years old, and still great. They also service what they sell. Make sure you are sitting down when you see the prices though. -- The only easy wood project is a fire |
308 days ago |
Raising the blade high above the wood reduces burning also, the Forrest rep gave me that tip at a recent woodworking show where he was cutting cherry without burning. He also used blade stabilizer. |
308 days ago |
If you get significant burning then chances are your fence is a bit closer to the back of the blade than the front. This causes the wood to be pushed into the teeth at the back of the blade. Those teeth don’t really cut the wood very well, though, because they are going in the wrong direction. You might actually be able to look at the burn marks and see the direction of the burn; meaning the shape of the burn will look more like the arc of the back of the blade than the front. The solution then would be to adjust your fence so that the back of the fence is pushed a bit more to the right (assuming your fence is to the right of the blade). It’s even OK if your fence is the slightest bit out of parallel to the blade, as long as the back of the fence is further from the blade. This might cause a bit of burning on the waste side of the cut, but it should be minimal, since there is no fence pushing the wood into the back of the blade. The only source of pressure would be from the wood itself and there isn’t anything you can do about that. -- Disappointment is an empty box full of expectation. |
308 days ago |
Thanks everyone. I just found a Freud 24 T rip blade for $60 locally. I think I may try to pick this up…unless I hear it is a dog! -- Ellen on Cape Cod |
308 days ago |
ellen…all of the above is super good info and correct..however if you will cut your wood close ,say to within 1/16, then skim the last 1/16 in as smooth and flowing a cut as possible, trying not to have “pauses” in your feed rate you will not get burns and you will also get a nice smooth cut…I often use the freud 24t glueline rip, its a super blade…personally i prefer the freud blades over most of the other expensive ones..which I have. |
308 days ago |
Charles has a good point… that’s what I sometimes do – cut it a little -- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html |
308 days ago |
Also as well as making sure your blades are sharp ,don’t feed too quickly, and add a little spray wax on the blade frequently and you’ll notice a big difference Alistair -- excuse my typing as I have a form of parkinsons disease |
308 days ago |
its all in the blade and the set up. -- making sawdust.... |
308 days ago |
spray wax???? -- Ellen on Cape Cod |
308 days ago |
I think a 40 tooth blade is what I would use. Plenty course enough to rip with and would give you a smoother edge than the 24 tooth. I also agree with raising your blade above the work. I use mine at about 3/4” higher when ripping. But only raise it to what you are comfortable with. The longer the distance the more heat is generated, contributing more to burning. The spray wax, is used on your blade to help keep pitch from building up on the teeth. |
307 days ago |
use a 24 tooth blade. i have a 40 tooth blade and i get burning with that. and what MR Neil said is always great info. just sneak up on it! |
307 days ago |
This forum has become a tutorial in ripping maple for me! WOW!! -- Ellen on Cape Cod |
307 days ago |
Sharpen your blade, re-allign your fence, raise the blade up, push wood through without stopping. |
307 days ago |
Yes, what bently and everyone else said. If you get a lot of burn, it’s either a dull blade or a fence (and or blade) out of adjustment. Just take your time and tackle one at a time, you’ll get it. Good luck. -- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood. |
307 days ago |
If possible I’d also cut down the 6-8 foot lengths to a little longer than what your project needs. I find it hard to control such a long board without a helper. -- Joe |
307 days ago |
I agree with bentlyj also…I invested in a 40 tooth CMT for about $90 and it does everything. Not only rips great, without burns, but also crosscuts good and is great on plywood and melamine. If you’re planning on investing $60, why not spend a little more and get a blade that can do it all. Just remember to keep it clean. -- Childress Woodworks |
307 days ago |
I work with old maple flooring and know the burns…they’re soooo hard to avoid. I did recently buy the Freud 24 tooth ripping blade (got it for $30.00 though) and it does help greatly, but there are still occasional burns. So I just touch them up with my hand plane! If you have a jointer, then all the better. -- Bob Vila would be so proud of you! |
306 days ago |
Thanks to you all for your ideas, encouragement, and general help. Today I bought a Freud 24 T rip blade (I could not get the 40 T locally) and some blade cleaner (for later). So…I will be changing out my old blade for the new one, raising the blade well above the wood, taking my time to work the fence alignment AND leaving about 1/16 of an inch over my measurement to shave off at the end. LJs is just the best web site I have ever found! I will post this simple contemporary bookcase when i finish it. Thanks again to you all! -- Ellen on Cape Cod |
306 days ago |
You might want to throw in a featherboard into the mix to keep the boards tight to the fence. If possible setup another featherboard to keep the work press down on the table. If you can keep the board moving in only one direction you will likely reduce the potential amount of burn you will see. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
306 days ago |
Put me in the REAL RIP blade camp. My favorite all ‘rounder is a 40T WWII, but sometimes the 24T rip blade is very helpful. I can use a more reasonable feed rate with the lower tooth count blade, even stop, without burning. I do lots of ripping with the 40T WWII, but find it’s worth the change out effort with maple, cherry, white oak, and woods thicker than ~ 1 1/4”. If I must (because I’m too lazy to change the blade) rip with the WWII, I’‘ll try to keep the feed rate to a higher speed, as fast as the saw will cut the stock. Remember, many times a minor burn might be of no consequence, as it’ll be hidden in the assembled piece, or planed off during hand fitting. -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
305 days ago |
hey guys. I do segmented turnings so I need thin rips from hard woods. the best way I found is a good rip blade like Freud . Malcolm Tibbetts at www.tahoeturner.com has a carrier for such a job. the “pushstick” has to be straight and square. mine are 3” wide x 30” long x 1/2 and 3/4 thick. bring your fence to the blade and back it up to the thickness you want to rip. tape the piece to be ripped to the push “stick” and run it thru. masking tape will do just fine. leave the fence there , remove the wood , the tape and retape the remaining wood for another cut. your rips will be all the same. it works. take care John -- retired and smiling |
293 days ago |
Ellen, The advice to raise the blade higher above the thickness of the board than you would with a regular cross cut, makes sense. I would caution that the blade and fence need to be in alignment and that you have a splitter or antikkickback pawls in place and you keep the board tight against the fence. Raising the blade increases exposure to kick-back. You know all this, but it bears repeating. Enjoy your new saw blade. Dalec |
293 days ago |
not to be old fashioned, but I rip on the table saw close but not on the line, then finish with a swipe of the #7 jointer handplane. Makes for a nice edge. -- "That which has in itself the greatest use, possesses the greatest beauty." - Unknown Shaker |
292 days ago |
Thanks all…I ripped that maple without a trace of burn! -- Ellen on Cape Cod |
291 days ago |
Wow, I just found this forum and have been learning some vital information immediately! I’m planning to build a workbench that will have a high maple content. This thread has saved me from several mistakes and has given me some great instruction. I’ll be ripping some 8/4 and 4/4 maple on my little Makita 10” bench saw, so I need all the guidance I can find. This thread has been very informative. -- Hammer to fit, paint to match! |
290 days ago |
Alignment,alignment, alignment, blade to to miter slot first then blade to fence, and a good riving knife helps too ! -- Scot, Alabama |
290 days ago |
Very good info! I Was using an 80T Oldham… Time to go shopping! -- Chris, South Carolina |
289 days ago |
You should only raise the blade enough so it can cut the wood without burning a 24 to 40 tooth blade will help but I pefer a 40 tooth blade. -- CJIII Future cabinetmaker |
289 days ago |
I am in the true 24T ripping blade camp too. The shavings that come from ripping are very different from the little chips that are created by cross-cutting. Ripping is much like planing…you get long curly shavings, and they need somewhere to go. That is the point of the blade’s tooth shape…..and tear-out is virtually never an issue. Cross-cutting blades use ATB style teeth to sever the grain to minimize the possibility of tear-out. This is not only un-necessary for ripping, it actually fights with the process. |
289 days ago |
I first flatten the board and then use a 14 tooth 12” blade for ripping. Then edge the board on the jointer. Gives a perfect board every time. -- Oldworld, Fair Oaks, Ca |
| Forum | Topics |
Woodworking Skill Share
2907 |
3929 |
256 |
946 |
223 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2374 |
LumberJocks.com Site Feedback
522 |
