painting laminate cabinate doors: a twist
Forum topic by babbobubba posted 05-25-2014 01:59 AM 742 views 0 times favorited 1 reply Add to Favorites Watch
View babbobubba's profile
babbobubba
1 post in 1336 days
05-25-2014 01:59 AM
Topic tags/keywords: refinishing laminate doors repairing formica
I want to reface or refinish my cabinet doors. The doors are almond-colored laminate over MDF (I suspect) with 5/16’s oak strips applied to the the vertical edges (totally 1970’s…). Because the oak strips are ever so slightly relieved/rounded on the corners, there is a tiny ‘V’ between the edge of the laminate and the oak and a fingernail or credit card will drop into this gap. I worry that if I apply new laminate without filling the gap it will “telegraph” through to the new surface. The question is, what do I use to fill this gap? Epoxy? Water putty? I’d apply the patching material and give the whole surface a light sanding before applying the new laminate, or I might just patch and paint the doors.
What would you all advise using to fill the gap? Thanks.
1 reply so far
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1945 days
#1 posted 05-26-2014 09:24 PM
Bondo.
-- Who is John Galt?
