Desk/bench design
Forum topic by Muggz posted 312 days ago 174 views 0 times favorited 1 reply Add to Favorites Watch
View Muggz's profile
Muggz
6 posts in 312 days
312 days ago
Topic tags/keywords: question
I was looking through some of the projects for an idea to build a gift for a little girl that I know very well that has Down’s syndrome. I came across a project that was a bench with a desk. She is turning 5 this April, what a great idea!
A couple questions I have. I am in the rough design of the project and I had some ideas:
Have a solid slab for the desk and the bench top or just use regular lumber. If it’s possible I want to stay away from plywood. I want to make it a little fancier because she is special to me. Is it possible to use dovetail jointery on boards that are glued together to make a solid wide board? I’m worried about doing it that way because of warpage.
Otherwise I was wondering if it’s possible to dovetail maple or oak plywood or something to that type. I haven’t worked with that type of plywood much so I’m not sure what my options are. It has to be relatively light so it can be moved around; I was thinking about installing wheels underneath that are hidden so it can skoot across the carpet.
View motthunter's profile
motthunter
2079 posts in 697 days
312 days ago
Obviously the final decision is yours. You can attache a solid wood frame around the ply and dovetail into this wood. Plywood can be dovetailed and reates a pretty industrial look. Use your imagination
-- making sawdust....
