Need help translatingmy thoughts
Forum topic by Thrain98 posted 05-23-2014 01:32 AM 889 views 0 times favorited 9 replies Add to Favorites Watch
View Thrain98's profile
Thrain98
20 posts in 2238 days
05-23-2014 01:32 AM
Topic tags/keywords: question
Ok guys,
I plan on building some pantry cabinets for my significant other, and I have an idea in my head of something I kind of want to do, but I’m having trouble getting the concept down and figuring out exactly what “technique” I’m thinking of (if it exists).
Here’s the concept, I’m hoping you guys can help me identify/clarify:
The best way I can think to describe it, is like an inlay of a scroll sawn piece, possibly across the doors of the cabinets…. This picture was something crude I just threw together to kind of illustrate what’s rattling around my head… Am I completely crazy? Is this a real technique? Is there a better way to accomplish what I’m thinking? Please help!!! :)
9 replies so far
View mahdee's profile
mahdee
3874 posts in 1735 days
#1 posted 05-23-2014 01:54 AM
No, not too crazy… Insane; maybe… The thing you have to work out is the gap to make it come out right.. You may also need to make the vertical boards wide enough to cover the whole image instead of running into the panels. You can do it.
-- earthartandfoods.com
Thrain98
#2 posted 05-23-2014 02:06 AM
Oh, well I guess I also picked a bad reference image too then, because I wasn’t necessarily thinking of the panel style doors like this, more the flat “regular” style…. mostly plywood was the original thought
Thrain98
#3 posted 05-23-2014 02:10 AM
Would this maybe be easier/better to do with something like a veneer inlay/marquetry type technique, rather than my initial thought?
View Yonak's profile
Yonak
986 posts in 1489 days
#4 posted 05-23-2014 02:19 AM
I’d be wary of inlaying into plywood. It’s likely you will get veneer chipout. How about panel and frame doors with ballooned stiles (and center rails, if used) large enough for your inlay ?
I don’t see the gap between the doors as a hindrance. It’s just a matter of getting the gap right and lining up the doors.
Thrain98
#5 posted 05-23-2014 10:08 AM
Wouldn’t that be where something like marquetry would come in though? Or is marquetry typically much smaller pieces than this?
View MrRon's profile
MrRon
4719 posts in 3211 days
#6 posted 05-23-2014 09:30 PM
Could you use a wood burning tool?
Thrain98
#7 posted 05-23-2014 09:38 PM
If I had one, I’m sure i could :)
Thrain98
#8 posted 05-24-2014 12:40 AM
Ok, follow-up question…. is it possible to do an inlay AND a surface veneering of the same area? For example, the plywood side of a cabinet, with a veneer applied to it, and then an inlay?
Yonak
#9 posted 05-24-2014 02:21 AM
Here’s an idea : If the inlay isn’t fancy wood, how about putting your inlay pieces under the veneer and draw the veneer down over it ? The veneer would have to be soaked first. ..Just a kooky idea I had.
