Table Saw Shroud Dust Collection
Forum topic by carrmatt02 posted 05-22-2014 10:31 PM 1950 views 0 times favorited 7 replies Add to Favorites Watch
View carrmatt02's profile
carrmatt02
5 posts in 1431 days
05-22-2014 10:31 PM
So I recently picked up a new table saw (Porter Cable contractor version) and I hooked it up to my dust collector, made some cuts and low and behold, there was still dust underneath the saw. So I looked underneath and there was about a good 4 inch gap between the shroud housing and the bottom of the top. I did some investigating of other contractor table saws and noticed that the only model that made an attempt to close this gap and keep the blade mostly enclosed was the high end dewalt version.
My question is, has anyone else come across this and tried to remedy the problem without using duct tape? I also realize that I will not catch all the dust from the saw until I collect on top of the blade as well.
Help is appreciated and this is my first post.
Thanks.
7 replies so far
View sawdustjunkie's profile
sawdustjunkie
382 posts in 1683 days
#1 posted 05-22-2014 11:00 PM
No contractor saw has great dust collection. You need to close it up as much as you can to get decent dust collection. I used hardboard to enclose it in.
I have a Craftsman and enclosed it completely and I still get some dust flying around.
Wear a dust mask as a minimum to keep from breathing it all in.
-- Steve: Franklin, WI
View knotscott's profile
knotscott
7980 posts in 3341 days
#2 posted 05-23-2014 01:17 AM
Are you talking about a true full size contractor saw with a belt drive motor or a portable jobsite saw?
carrmatt02
#3 posted 05-23-2014 01:58 AM
It’s a portable.
I would sheet metal screw a piece of sheet metal then tape the tops but I don’t know if I want sheet metal screws sticking through.
View Paul's profile
Paul
721 posts in 1531 days
#4 posted 05-23-2014 03:49 AM
You have a portable, job site table saw. I recently replaced my job site saw for the shop. The job site saw stays in my truck where it belongs. A job site table saw is not built for dust collection, period. After a year with mine in the shop I gave up on dust collection with it. You will spend far too much money trying to machine fittings etc that are not meant to be there.
My job site saw is a dw744 it has adaqeut dust collection on the job site with a shop vac but does not belong inside a shop IMHO.
Paul
carrmatt02
#5 posted 05-23-2014 03:56 AM
Unfortunately, I only have half of a garage for a shop so I dont have enough room for a full size saw. Thanks for the input.
View Paul's profile
Paul
#6 posted 05-23-2014 04:03 AM
Carrmatt,
A true contractor table saw or hybrid will table up roughly the same area as a job site saw. My steel city contractor saw takes up about 4 sq ft more room than I had with a job site. It has a mobile base and I move it around.
Can see my saw in my workshop if you click on my name. I work in a 20’ x 15’ work shop. It’s likely smaller than your half a garage.
Paul
carrmatt02
#7 posted 05-23-2014 04:27 PM
It’s more like 10’ x 15’ or smaller. It’s pretty tight and occupy where the wife parks her car for larger projects. So, everything has to be portable… Long story short, I need a larger shop.
