Is a 5/8" arbor safe, or too weak?
Forum topic by DennisA posted 05-22-2014 06:46 PM 2450 views 0 times favorited 49 replies Add to Favorites Watch
View DennisA's profile
DennisA
13 posts in 1707 days
05-22-2014 06:46 PM
Topic tags/keywords: question tablesaw
I’ve had more than one european woodworker tell me I shouldn’t get an american style table saw (I am in finland) because the arbor is 5/8” and that’s just too weak for any serious stuff (such as ripping long rough sawn lumber).
I figured I should ask the americans what you think. Seems to me even more serious machines use the 5/8s arbor and it seems to work okay? Is it the 5/8” arbor a weak point in a table saw you think, would you prefer a 25mm or 1” arbor? Or doesn’t it make a difference?
I like this american contractor style saw I found, it can even take dado blades, also has a 1phase 3HP induction motor and cast iron top. It would bring the total to 1k euros to bring it home from the UK though. He has pointed out some old machine by a company called Griggio instead, a combined saw and spindle molder, for 600 euros, but it’s in pieces and need some parts replaced, says the total to get it running will probably come to the same as the UK saw.
So I am at a bit of a loss, I am new to woodworking and somewhat lost.
49 replies so far
MrUnix
7114 posts in 2440 days
#1 posted 05-22-2014 07:47 PM
The Delta Unisaw (and PM66, Grizzly G1023, etc..) has a 5/8” arbor and I have never ever heard anybody complain about it or claim it is a ‘weak point’..
View crank49's profile
crank49
4032 posts in 3212 days
#2 posted 05-22-2014 08:10 PM
It would take over 30,000 lbs of force to break the 5/8” arbor shaft.
Europeans are always speculating how much better their designs are than ours.
That’s why they invented the electric light, the phone, space travel, computers, the internet. . . oh wait.
5243 posts in 2734 days
#3 posted 05-22-2014 08:13 PM
If you look at the millions of hours logged on those saws with 5/8” arbors and could figure out the failure rate (I’m sure there have been a few, though it’s so low it would be considered insignificant) I think you would find it to be just as good as whatever the standard is in Europe. While I think the European tools have some advances over those here in the states, I can’t imagine that being one of them.
View TheJBitt's profile
TheJBitt
34 posts in 2199 days
#4 posted 05-22-2014 08:18 PM
AS an engineer, I 2nd what Crank said about ridiculous forces necessary to break the arbor.
As a cheapskate, I would like to point out that you say the Griggio is a saw AND a spindle shaper. I don’t know anything about Griggio, but if it is a decent quality machine, why would you not jump on it and get double the functionality for the same price?
-- I make great sawdust. -Jon in Warsaw, IN
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2611 days
#5 posted 05-22-2014 08:27 PM
As an engineer as well, I would turn back to you friend and ask for the supporting data to that argument. My guess is that there is none, just a bunch of hearsay. If you’re going to state something as fact, you’d better be able to back it up. If he can’t back that up, I’d question the credibility of anything else that comes out of his mouth. I’m not saying you shouldn’t be friends with him, but all advice, as well as the advice from an internet forum, should be taken with a grain of salt.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3826 days
#6 posted 05-22-2014 08:58 PM
It seems that the arbour is quite strong enough, at five eighth’s of an inch.Please don’t worry there is plenty out there which will get you first.Like Perpetual constipation for example.Alistair
View Mike Throckmorton's profile
Mike Throckmorton
124 posts in 1906 days
#7 posted 05-22-2014 09:19 PM
The 15.875mm arbors are much much stronger.
-- You are never complete, you just draw a line where done is and stop at that line.
View Underdog's profile
Underdog
1250 posts in 2277 days
#8 posted 05-22-2014 09:25 PM
Yeah, because 15.875 is a bigger number than .625.
-- Jim, Georgia, USA
Underdog
#9 posted 05-22-2014 09:28 PM
We used a PM table saw with a 5/8” arbor w/ a 3 HP motor for years to rip down long lengths of lumber in the cabinet shop. Now we’re using a SawStop with a 5 HP motor and a 5/8” arbor to rip down long lengths of lumber…
Never. Been. An. Issue.
Buy whichever one you want.
View Mike67's profile
Mike67
97 posts in 3577 days
#10 posted 05-22-2014 09:32 PM
Wait, do you rip rough lumber? That’s not safe. You need to joint an edge and face first.
Are blades for use with 5/8 arbors easily available there? That could be a factor.
View InstantSiv's profile
InstantSiv
262 posts in 1836 days
#11 posted 05-22-2014 09:37 PM
I would disregard their advice…
Instead I would look at what saw blades, arbor wise, are readily available in your area. If 1” or whatever seems to be the most common, cheapest, available locally,... I would base my decision to get or not get that saw on that.
View Matt Rogers's profile
Matt Rogers
110 posts in 2211 days
#12 posted 05-22-2014 09:49 PM
I know this is off topic, but Mike67 – do you really think that it is that unsafe to rip rough lumber? If so, then how would anybody make battens from rough cut lumber for board and batten siding? Nobody is going to take a 16’ long board to the jointer and a lot of rough cut siding comes from a guys with a mill, but no molder to S4S or even S1S a long board.
I do agree that sending really gnarly boards through the table saw could be a hazard – like a 2” thick warped and twisted slab of hard maple with tension wood, but I and many others have safely ripped thousands of feet of rough 1x pine boards for siding on many different table saws without any serious kickback or danger. A splitter is certainly recommended
Rough lumber is commonly ripped to a width that is close to the size of piece that you will be using before jointing as you can take a cupped 8” wide board and cut it into two 4” blanks for cabinet door parts, then joint each piece individually and get flatter wood more quickly and with less waste than if you tried to joint the wide 8” board first.
Not trying to bust your balls, but it is not true that is is always unsafe to cut rough lumber on a table saw.
-- Matt Rogers, http://www.cleanairwoodworks.com and http://www.cleanairyurts.com
View unbob's profile
unbob
810 posts in 2144 days
#13 posted 05-22-2014 09:54 PM
Many European woodworkers think dado stacks are completely dangerous, and they are not allowed anyway as the blade guard must be removed for use. Those operations are done on other machines.
They tend to have a lot more government rules. It seems the saws sold there have only a short arbor, for ones own good.
Ripping rough sawed wood on a table saw, seems a little bit of a hazard to me, perhaps more so on short lengths.
Matt made some good points above, I am glad he posted that.
View bbc557ci's profile
bbc557ci
595 posts in 2315 days
#14 posted 05-22-2014 10:32 PM
Bull. When was the last time anyone heard of an arbor breaking. And if so, what led to the failure. No one in their right mind, or with some common sense and or experience would shove a twisted piece POS wood through a table saw. At least I wouldn’t think they would.
-- Bill, central NY...no where near the "big apple"
View Yonak's profile
Yonak
986 posts in 1762 days
#15 posted 05-23-2014 02:58 AM
Re : “and they are not allowed anyway as the blade guard must be removed for use.”
unbob, is it illegal to remove the blade guard in the privacy of one’s personal shop in Europe ? Our OSHA in the US goes overboard at times, but at least they don’t pester the home woodworker.
showing 1 through 15 of 49 replies
