Plywood Span help for seating bench
Forum topic by hammester posted 05-22-2014 03:49 PM 1442 views 0 times favorited 4 replies Add to Favorites Watch
View hammester's profile
hammester
11 posts in 2467 days
05-22-2014 03:49 PM
I am planing on making the attached storage seating bench this weekend but am unsure if it will work or not. I am concerned with the vertical spacing that I have. With people sitting on the bench I am not sure if it will sag or not. I am planing on using 3/4” plywood for the top and bottom of the bench and using 2×4 to build a frame to hold them. The vertical slats would also be made of 3/4 plywood. I just don’t think that will be enough to support the weight of people sitting. Any ideas how to achieve such long spans between the vertical slats (44.5”) I plan to put a face frame on it using 1×2’s.
View ChefHDAN's profile
ChefHDAN
1057 posts in 2813 days
#1 posted 05-22-2014 04:40 PM
Hammester, we’re gonna need a better image, at 300% I can’t even make out the specs
hammester
#2 posted 05-22-2014 05:18 PM
Sorry about that didn’t realize how small it was. I uploaded it to photobucket so hopefully that makes it more readable.
View pintodeluxe's profile
pintodeluxe
5620 posts in 2777 days
#3 posted 05-22-2014 06:09 PM
A 2×4 set vertically over a 44” span should be fine. A 2×4 laid flat will sag a little. The 3/4” plywood will help to add some structure.
View gfadvm's profile
gfadvm
14940 posts in 2654 days
#4 posted 05-23-2014 01:01 AM
Like Pinto said. Make the frame under the top from 2×4s on edge and it won’t sag.
