"re-hydrating" dried wood?
Forum topic by jdh122 posted 05-22-2014 02:29 PM 901 views 0 times favorited 3 replies Add to Favorites Watch
View jdh122's profile
jdh122
983 posts in 2723 days
05-22-2014 02:29 PM
I got some ash logs recently (thanks to LJers for helping me identify the wood) and have started riving and shaving chair parts. But the wood is very dry (I don’t have a moisture meter so can’t give numbers, but it’s easy to compare it to my experience working other species green). Very hard to work, to the point that it’s probably not worth the bother. I’ve been debating sticking the logs into some water for a few weeks to make them easier to work. Anyone have any experience with doing something like this? Think it’ll work?
-- Jeremy, in the Acadian forests
3 replies so far
View mahdee's profile
mahdee
3844 posts in 1673 days
#1 posted 05-23-2014 12:57 PM
You can moisten it, put it in a container, wrap it in plastic or put in a small tent. Leave in the sun for few hours and do your shaping until you hit dry spots and repeat. Doing this you introduce moister to the outer 1/8-1/4” and probably won’t experience too much checking and cupping. Good luck.
-- earthartandfoods.com
jdh122
#2 posted 05-23-2014 03:18 PM
Thanks for the advice. I can’t quite figure out why it’s so dry, since it was part of a tree only a few weeks ago. Maybe just because it was cut in the winter (all the other drawknifing work I’ve done has been on summer-cut wood) or whether the tree was dead, although I don’t think that’s the case). In any case I guess I have nothing to lose trying to moisten it.
mahdee
#3 posted 05-23-2014 04:20 PM
I have not had too much experience with ash mainly because I bought a few hundred b/f and by next year the boards were eaten by the bugs so bad that I ended up burning the whole thing.
