air drying - at what % MC is it safe to bring indoor
Forum topic by martin007 posted 01-20-2009 01:52 AM 791 views 1 time favorited 4 replies Add to Favorites Watch
View martin007's profile
martin007
142 posts in 3681 days
01-20-2009 01:52 AM
Hi All
I got a pile of cherry lumber from different sources, MC range between 14% and 25%.
I wonder at what % of MC is it safe to stack indoor (heated garage in my case)
thANKS
-- Martin, Gatineau, Québec
View 8iowa's profile
8iowa
1569 posts in 3667 days
#1 posted 01-20-2009 02:03 AM
When we take the brutal cold Northern winter air and heat it in our homes the humidity drops to Sahara desert levels. Even a humidifier on the furnace might only bring the relative humidity up to around 40%.
Without digressing any further. It might be a good idea to “sticker” the lumber when you first bring it inside so that drying will be more uniform.
View motthunter's profile
motthunter
2142 posts in 3704 days
#2 posted 01-20-2009 02:05 AM
hard to say. normally 10 to 12 will work fine. Some bring it in around 15
-- making sawdust....
martin007
#3 posted 01-20-2009 02:35 AM
yes I will use stickers inside, so the MC can eventually come down close to 10%.
View John Ormsby's profile
John Ormsby
1283 posts in 3642 days
#4 posted 01-20-2009 03:21 AM
Make sure you do not create a mold problem in your home with a lot of green boards. It can create some big problems.
-- Oldworld, Fair Oaks, Ca
