| Forum topic by marcb | posted 311 days ago | 446 views | 2 times favorited | 18 replies | ![]() |
311 days ago |
I am just about ready to fire up my Jointer for the first time. I have never used one of these machines myself. I’ve had a friend run a few parts for me in the past (I soley hand jointed for a long time, but larger parts take a lot out of me). I have read all the horror stories and some suggestions, but I was wondering if there was a definitive resource on using a Jointer safely. |
311 days ago |
Here are a couple of videos on using jointers. Ehow,com and Marc Spagnolo's The Jointer is Jumpin' Video Hope this helps. The jointer is a tool that you should never lose respect for as it is one of the most dangerous tools that we choose to work with. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
310 days ago |
Push blocks! And keep your hands away. Bloodstains are really hard to get out of unfinished wood. Remember it’s not all that different from the woodchipper that the treetrimmer uses. But also remember that millions of high-school kids have used jointers successfully for decades, too. |
309 days ago |
Im usually a bit hesitant to give advice on tool usage as there is always more than one way to skin a cat, but the jointer can be a career ending machine if not used correctly. I was trained by an old guy who who began his career before WW2 so I have no reason to doubt what he said. He still had his fingers. -- if the hand is not working it is not a pure hand |
309 days ago |
Thanks for all the pointers. I have had zero accidents with power tools so far by sticking to 1 rule, fingers don’t go near the spiny part. I have to finish the cart that it will be mounted too and wire in the switch, after that I’ll be jointing with the best of them. |
308 days ago |
Always have respect for your power tools, but don’t be afraid of it. In my work as a paramedic most industrial and workshop accidents I see are from carelessness and just plain stupidity like pushing pieces threw to fast , poor tool maintenance, and not paying attention to what you are doing. second always be aware of your hand placement, and dont try to remove all your stock in one pass I personally make multiple shallow cuts, and trry to use push pads as much as possible. I also try to stick to one simple rule (actually 2 ) in my shop, when visitors show up to gab the tools are turned off, and no test pilots allowed to touch my tools, I dont want any blood on my stuff! -- rob, ont,canada |
307 days ago |
Some woodworkers use a jointer extensively for milling rabbets and surfacing wide boards. To each his own, but I now use the jointer only for jointing edges in preparation for gluing. This keeps my hands far away from the cutters. I use a dado for rabbets, and a hand plane and winding sticks to remove twist and cup from a board before the trip thru the thickness planer. Nick Engler described the jointer as a “meat grinder”, grabbing ahold of you and drawing your hand further in. -- "Heaven is North of the Bridge" |
290 days ago |
So, how you doing with the jointer marcb? -- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood. |
288 days ago |
I have a bunch of jointer related stories around my site. The Basics story is at the link below. Take your time and get used to this machine, It is invaluable in the shop but can be a real pain in the hinder if you develop bad habits. http://www.newwoodworker.com/basic/usejntr.html -- Tom Hintz, www.newwoodworker.com |
288 days ago |
Welcome to Lumberjocks, Tom. You have a great web site. It is a gold mine of information and I’ve used it for a while. -- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood. |
288 days ago |
Tom – thanks for the link and the resource, great write up, and easy to follow! -- When in doubt - There is no doubt - Go the safer route. |
288 days ago |
trry always to read as much about machinery which causes you to have any anxiety.When I bought my new sliding saw I didn not switch it on to use it for nearly two weeks .First I ran dry runs through it and fitted extra footcut off switches and safety stop switch and also remodeled the guard making my own new fence and overhead guard copying biesemeyer and I would advise with a planer jointer to do some dummy cold runs with the machine off for a while til you get ready to cut it is not desperately dangerous.And if you work out everything beforehand it should provide you with peace of mindAlistair -- excuse my typing as I have a form of parkinsons disease |
285 days ago |
285 days ago |
Last weekend while I was up visiting my parents my Dad gave me a book he found. It’s about How to use all the tools in your woodshop and was published by Craftsman in 1955. The fun part is that they of course used all of their current woodworking tools for the illustrations and examples, and the above unit falls right into that time line. |
285 days ago |
I can add one thing to Kiwi’s remarks. Never wear gloves and keep the guards on. I can tell you from experience. -- Jerry--A man can never have enough tools or clamps |
282 days ago |
Very good point about the gloves! -- if the hand is not working it is not a pure hand |
282 days ago |
marcb, The advice I can give is to never have your hand on the part above the cutter or foward of the cutter. For obvious reasons if the peice is kicked your hand can drop or be pulled into the cutter. This may sound like a no brainer but when you have a small piece and it is chattering then you may be very tempted to put your hand in there to stabilize it. If your hand is behind the blade, it wont drop into the blade. I do have quite a few jigs for joinering thin peices and I will share them once I figure out how to get pictures and drawings up. Have fun with your joiner. Cheers, Ben |
282 days ago |
Ben, Thanks, I’m pretty paranoid about getting near blades so I’ve been doing that, but I’ll ensure that I keep it in mind later. I think 12” minimum for length is where I’m going to keep my rule of thumb. |
282 days ago |
OK, here goes… I face joint with grippy gloves. <g> My hands never get inside the area where the pork chop resides. Once the pressure transfers to the outfeed table, neither hand is ever near the cutterhead. I get much better results than push blocks. The stock is ALWAYS positively held, which can’t be said for push blocks. When edge jointing, I go with bare hands. I also wear a snug-fitting glove, or sometimes carver’s tape on the fingers, on my left hand, while ripping This is to protect my thumb and fingers from slices from sharp edged wood. Again, the gloved hand never gets within a foot of the blade. I have an overhead guard specifically for ripping. These are personal choices that I’ve developed with many years of experience and a complete understanding of the physics involved in the respective operations. I don’t recommend anyone else try it, because the devil is in the details. I am confident that I am safe, just as I am flying inside a cloud with no exterior reference. I only bring it up in response to the nevers… -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
| Forum | Topics |
Woodworking Skill Share
2916 |
3944 |
256 |
949 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2386 |
LumberJocks.com Site Feedback
524 |
