Jigsaw Ability
Forum topic by SuSpence posted 05-20-2014 03:17 PM 711 views 0 times favorited 4 replies Add to Favorites Watch
View SuSpence's profile
SuSpence
7 posts in 1359 days
05-20-2014 03:17 PM
I am planning of trying some bent lamination and am wondering if my jigsaw will be able to cut my MDF molds. The molds are 4” thick. My jigsaw is a 5.0 amp variable speed craftsman. Is that too much material for my jigsaw to cut through at one time? I don’t have a bandsaw so I think a jigsaw is my best option. Thanks!
9765 posts in 3520 days
#1 posted 05-20-2014 03:35 PM
Too much material for any jigsaw but a very pricey Mafell.
When I make molds, I make a pattern from something like 1/4”
hardboard which I screw to 3/4” layers and make a bunch
of duplicate layers from the pattern using a pattern copy bit
in a router. In your case, you would draw a line from the
pattern, jigsaw outside the line, screw the pattern to the
part and trim with the router.
Layers can be kept aligned when you glue them up by
driving positioning screws or air nails.
View ChefHDAN's profile
ChefHDAN
1007 posts in 2722 days
#2 posted 05-20-2014 04:56 PM
+1 Loren
View bigblockyeti's profile (online now)
bigblockyeti
4885 posts in 1593 days
#3 posted 05-20-2014 05:01 PM
Sounds like it would be overworked, even with a big blade (which are available) there are better options. First being a bandsaw, if you’re good, you could use a reciprocating saw which would result in a surface that needed much sanding and most likely not square.
View TheFridge's profile
TheFridge
8659 posts in 1358 days
#4 posted 05-20-2014 05:25 PM
