The ticking table saw
Forum topic by Boerseun posted 05-20-2014 02:37 AM 2149 views 0 times favorited 34 replies Add to Favorites Watch
View Boerseun's profile
Boerseun
17 posts in 1668 days
05-20-2014 02:37 AM
After shutting down my shop and selling all of my industrial machines I was the lucky recipient of a Craftsman 315 series – the saw has run well for the past 6 months but recently it has developed a nasty tick/knock which seems to be stemming from the arbor assembly – does anyone have experience in this area?
34 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3680 days
#1 posted 05-20-2014 05:17 AM
Does it do it when you spin the blade by hand, on start up or slow down, or does it tick all the time?
View TheFridge's profile
TheFridge
9249 posts in 1454 days
#2 posted 05-20-2014 05:39 AM
I have a 315.228410 that ticks on and off, but I’ve never really had any problem. I think mine is from my motor though.
Boerseun
#3 posted 05-20-2014 12:56 PM
Well that would be the weird part – if I disconnect the belt and spin the arbor manually there is only a very faint knock every 1/2 rotation. Conversely with the belt disconnected the motor runs almost silently (as quietly as a motor of its age can.). Connect the operation and the problem rears its head. I will upload a video this evening.
View generic's profile
generic
105 posts in 1566 days
#4 posted 05-20-2014 04:25 PM
I had a sears contractor’s saw that had a similar noise. when I looked closer, the drive pully on the Arbor shaft had loosened and slid to the side. Moved it back and tightened it, the noise went away.
View bigblockyeti's profile
bigblockyeti
5096 posts in 1688 days
#5 posted 05-20-2014 04:52 PM
The symptoms you are describing certainly sounds like a loose driven pulley.
View TiggerWood's profile
TiggerWood
271 posts in 1574 days
#6 posted 05-20-2014 11:05 PM
If it’s not the drive pulley:
I had this happen and found that the bearing on the pulley side went dry (but not bad). If you carefully take the arbor off, you can re-grease them with either a bell jar or heat vacuum. Or just buy a new one for four to six bucks.
Boerseun
#7 posted 05-20-2014 11:46 PM
I’ve checked the drive pulley and the darn thing is tight and in alignment… Still scratching my head over this.
Boerseun
#8 posted 05-21-2014 12:03 AM
Alrighty gentlemen – below is the video
http://youtu.be/hwt4feNj18w
By the by – I am so grateful for all of the input and assistance.
TiggerWood
#9 posted 05-21-2014 02:29 AM
If it is the bearing/s (which I can’t think of anything else it would be), it sounds like at least one of the balls has a flat side. They would have to be replaced. I found two on Ebay for $8.95 with free shipping. I only replaced the bad one because the saw side bearing doesn’t come off.
Boerseun
#10 posted 05-21-2014 11:44 AM
Its unfortunate that one cannot remove the saw side bearing – I am hoping that its not the one thats gone for a loop.
bigblockyeti
#11 posted 05-21-2014 02:34 PM
That definitely sounds like a bearing to me.
generic
#12 posted 05-21-2014 04:13 PM
I’m sure that you have ruled this out, but I will ask anyway, do you have the belt guard on? Mine would make a sound very similar to that when the belt would get to close to the motor pulley. they keyway rubbing the plastic guard made a heck of a racket.
Boerseun
#13 posted 05-21-2014 04:16 PM
I think the bearings may be a good starting point… Worst case scenario I can find a donor saw and start to part it out. With regards to the belt guard, I removed it from the machine because it caused an impingement when lowering the blade down.
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1602 days
#14 posted 05-21-2014 05:00 PM
IMHO… Bearing
-- Jeff NJ
Boerseun
#15 posted 05-21-2014 08:13 PM
Bearings on the way…
showing 1 through 15 of 34 replies
