| Forum topic by woodspyder | posted 1580 days ago | 539 views | 0 times favorited | 6 replies | ![]() |
1580 days ago |
Topic tags/keywords: question I am finishing a project. I have 5 coats of dainish oil sanded to 400 grit between the last 2 coats. My question is do I sand again before I add a coat of poly? This is my first project in 19 – 20 years and then I only made a couple of picture frames/shadow boxes. -- Measure three times, cut twice. |
#1 posted 1580 days ago |
You will need to sand the project again. Poly adheres through mechanical bonding. So it will need a “roughened” surface to bond to. Just sand lightly with 400 grit, topcoat it with poly, wait overnight for it to cure and sand again before applying another coat. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#2 posted 1579 days ago |
On the other hand…. You can’t go wrong following Scott’s advice, but I have applied poly over Danish oil many times without sanding first, and never had a problem. -- Charlie M. "Woodworking - patience = firewood" |
#3 posted 1578 days ago |
be quite certain that the oil is dry, 5 coats is alot of oil to be topping with a poly..personally i would wait several weeks, just to be safe, and yes sand it as stated above, and |
#4 posted 1578 days ago |
5 coats? damn, some would call that over kill. But not me i like your style! lol. but definately sand before the poly. hell by the time youve got 4-5 coats of poly on the peice has prolly doubled in thickness ;) -- mwm! Before you criticise walk a mile in their shoes, and when you do criticise you will be a mile away and have their shoes! |
#5 posted 1578 days ago |
oh and dont forget to post the project!!!!!!!!!!!!!! -- mwm! Before you criticise walk a mile in their shoes, and when you do criticise you will be a mile away and have their shoes! |
#6 posted 1578 days ago |
Thanks for the help gang. I will post it when finished, and after I get some 6 year old to show me how to use the digital camera and load it to the desktop. Again thanks for the info. -- Measure three times, cut twice. |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15748 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
