Setting Planer Blades Delta/Rockwell/Invicta 22-650 or similar
Forum topic by Chris208 posted 05-19-2014 06:01 PM 3389 views 0 times favorited 2 replies Add to Favorites Watch
View Chris208's profile
Chris208
240 posts in 2510 days
05-19-2014 06:01 PM
Hello!
I bought the following knife setting jig from Woodcraft, but I’m not sure how to use it.
http://www.woodcraft.com/product/0/4444/small-planer-knife-jig-set.aspx
How far above the cutter head should the knives protrude?
The manual does not say, because this planer came with a jig that would automatically set the knives to the correct height. Needless to say, I do not have that jig.
Thanks,
Chris
2 replies so far
View cabmaker's profile
cabmaker
1744 posts in 3049 days
#1 posted 05-20-2014 12:24 AM
If you have knives installed presently just set up your magnets at the existing setting then remove and replace.
All things are important when setting planer knives but the relationship from cutter head to knife protrusion will not be as crucial as knife to pressure bar and in/ out feed rollers.
I’m sure a search will result in that data for you.
enjoy! JB
cabmaker
#2 posted 05-20-2014 12:28 AM
BTW after you have one setting jig set where you want it I would recomend setting the other one at the same location then compare the reading as the stick on scale may not be consistent from one to the next.
