HF SAND BLASTING GUN.
Forum topic by b2rtch posted 05-19-2014 10:43 AM 866 views 0 times favorited 7 replies Add to Favorites Watch
View b2rtch's profile
b2rtch
4847 posts in 2920 days
05-19-2014 10:43 AM
Topic tags/keywords: question
I am thinking about buying a HF SAND BLASTING GUN.
Which blasting medium should I get with it?
Thank you.
-- Bert
7 replies so far
View Don W's profile
Don W
18560 posts in 2439 days
#1 posted 05-19-2014 10:54 AM
I really don’t know what medium is good for what, but I do know it depends. I use black beauty for hand planes and things like that. It depends on what you want to blast.
View cutworm's profile
cutworm
1075 posts in 2665 days
#2 posted 05-19-2014 11:32 AM
Lots of folks on here use soda. I’m looking at a wet sandblaster for my pressure washer and trying to learn more about them.
-- Steve - "Never Give Up"
View mahdee's profile
mahdee
3830 posts in 1639 days
#3 posted 05-19-2014 11:50 AM
There are various course of sand to blast with. Best ones are the silica sand that is used in pool filters. However, be sure to wear a mask if you are using silica sand. I have used regular river sand to remove paint from a car.
-- earthartandfoods.com
View lateralus819's profile
lateralus819
2241 posts in 1761 days
#4 posted 05-19-2014 11:59 AM
I switched from black beauty to Glass beads, MUCH more affective, and faster. I also use a gun from tractor supply, which works wonders.
Don W
#5 posted 05-19-2014 12:25 PM
I’ve even used regular play sand. It needs to be good and dry however. Again, it depends on what your blasting. If you can capture and reuse, then one of the mediums is best, but if your doing something like a trailer frame, then sand may be cheapest.
b2rtch
#6 posted 05-19-2014 12:30 PM
Thank you all for your replies.
I have nothing specific in mind to clean but I would use it around the shop for planes and other tools and also for trailer frames and the like.
I think that it would handy to have around.
I have a 2HP/21 Gallons air compressor, how much this thing uses?
-- Bert
Don W
#7 posted 05-19-2014 12:39 PM
The cfm rating should be in the spec’s. A blaster takes a lot of air. you probably won’t get continual use with that compressor. I typically go do something else to let it catch up.
