Help with Drill Press ID
Forum topic by Don Broussard posted 05-19-2014 02:00 AM 1586 views 0 times favorited 13 replies Add to Favorites Watch
View Don Broussard's profile (online now)
Don Broussard
3417 posts in 2122 days
05-19-2014 02:00 AM
Topic tags/keywords: drill press
I got a new-to-me drill press this weekend. The motor works and the drill press operates, but I’d like to give it a good going over before I put it back to work. It’s a 15” Delta/Rockwell floor drill press with ½ HP, 120V Marathon motor. The serial number (127-6150) is legible but I don’t see a model number—I’m thinking it was on a plate or decal that is no longer a part of this package. It has 4 discrete speeds, adjusted by changing the belt position on the pulleys. I’m trying to identify the model number so I can retrieve an owner’s manual.
Here are a few pictures:
I suspect it’s from the late 60’s or early 70’s based on similar serial numbers and their known dates of manufacture. I would appreciate any assistance or resources you could offer. Thanks in advance for the help!
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
13 replies so far
View lightcs1776's profile
lightcs1776
4183 posts in 1524 days
#1 posted 05-19-2014 02:07 AM
Looks like a solid piece of iron. Congrats.
-- Chris ** If there must be trouble, let it be in my day, that my child may have peace. — Tom Paine **
Don Broussard
#2 posted 05-19-2014 02:18 AM
Thanks, Chris. It is very solid and looks complete but some of the parts need an attitude adjustment. I don’t expect that it’ll take too long to put back in service.
View tefinn's profile
tefinn
1222 posts in 2307 days
#3 posted 05-19-2014 02:57 AM
Hey Don, the serial number dates it as made in 1960. It looks like a model 15-207, but I’ve never seen one without the on/off buttons on the front of the housing. I hope this helps some.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
Don Broussard
#4 posted 05-19-2014 02:59 AM
Thanks, Tom! There is a plate over the opening where the switch “should” be, but I haven’t opened her up yet to see what lurks within. The switch is located in the back (orange box) near the motor. I’ll start with that model number and see how far I get. Thanks again.
View Dave's profile
Dave
11426 posts in 2710 days
#5 posted 05-19-2014 10:56 AM
Don thats one awesome piece of steel!
Good luck with it.
View Don W's profile
Don W
18559 posts in 2438 days
#6 posted 05-19-2014 11:12 AM
That should be a great addition to your shop.
View Heath's profile
Heath
37 posts in 3351 days
#7 posted 05-19-2014 12:56 PM
Don, check out http://www.vintagemachinery.org or the forums at http://owwm.org/. There’s a wealth of information there.
Here’s the Publication Reprints section for Delta (use the drop-down at the top to narrow it down to just drill presses): http://www.vintagemachinery.org/mfgIndex/detail.aspx?id=1141&tab=3 Maybe you can find it there. Also, check under the Rockwell manufacturer.
Looking through the Photo Index (again, narrowed to Drill Presses), I found several that look very similar to yours.
http://www.vintagemachinery.org/photoindex/detail.aspx?id=17278
http://www.vintagemachinery.org/photoindex/detail.aspx?id=17152
http://www.vintagemachinery.org/photoindex/detail.aspx?id=6642
http://www.vintagemachinery.org/photoindex/detail.aspx?id=16814
I have a fascination with vintage woodworking machines and have restored several. That is a pretty awesome drill press! Good luck with it!
-- "I am always doing that which I can not do, in order that I may learn how to do it." - Pablo Picasso
Don Broussard
#8 posted 05-19-2014 02:03 PM
Heath—After tefinn gave me the lead on a model number (which by the way, I think is correct), I visited owwm.org to try to locate an owner’s manual. I did the search similar to what you described and came up empty on the 15-207 manual. Still looking for the manual. Looks like the table took a beating—almost looks like someone tried some new metal carving techniques on the table with a hole saw. After I get his unit cleaned up, I’ll probably just build a larger wooden table and put over the stock table.
tefinn
#9 posted 05-19-2014 06:54 PM
Don, I tried looking for a manual also and came up dry. I really do believe it’s a 15-207 drill press though. I highly doubt the motor is original and that’s probably why the switches are no longer on the front of the head. I’ll keep looking for a manual and if I find one I’ll let you know where I find it.
View teejk's profile
teejk
1215 posts in 2555 days
#10 posted 05-19-2014 07:50 PM
I save all the manuals that come with my tools…when it comes to the drill-press I have to wonder why! Other than the new ones with electronics, I don’t think the basic design has changed since before I was born (if it ain’t broken, don’t mess with it). It is a beauty but I think I would be careful about doing too much with it. That decal on the front might be valuable.
Don W
#11 posted 05-19-2014 08:55 PM
is this it?
Don Broussard
#12 posted 05-19-2014 09:38 PM
@tefinn—I think you nailed the model number. I’ve been scouring resources looking for the manual using that model number in the search criteria. There are a lot of manuals and other publications on owwm.org, but not one for the 15-507 and looking under either Delta or Rockwell.
@teejk—You’re right about the decal. I don’t see too many with a full decal, so I’m not planning to mess with it at all. I’m more interested in the tuning specifications and bearing IDs. I’m not planning to do a full showroom restoration—I’m really just wanting it to be at its best before I put it to work doing what it does best. I know for certain that the quill return needs to be adjusted, the depth adjuster needs calibration, the pulley cover has a few dents that need attention, and the device that tightens the motor bracket that in turn tightens the belt needs adjusting. Of course the belt needs to be replaced too. I’m not sure if I want to return the switch to its original position in front of the head, but I might well end up doing that. The switch looks original as well as the motor.
@DonW—It could be, but there’s not much information on models numbers to which the manual could apply. The year of publication is about right though.
Don Broussard
#13 posted 05-23-2014 02:01 AM
@tefinn—I just noticed that I had a typo in my last post. I am looking for 15-207 as the model number (not 15-507 as incorrectly typed earlier). Still no luck with a manual. I’m also looking for other models by looks to see if there is a similar model too. No luck finding any matches based on the serial number either.
