Size of plywood needed?
Forum topic by Knothead62 posted 05-17-2014 04:32 PM 802 views 0 times favorited 2 replies Add to Favorites Watch
View Knothead62's profile
Knothead62
2584 posts in 2989 days
05-17-2014 04:32 PM
Topic tags/keywords: question plywood cabinets
I have two cabinet fronts that I want to finish into a storage unit for our kitchen. The slots on the back of the frame measure 14mm. or 0.551 in. or 35/64 in. I don’t find any plywood at Lowe’s that fits that dimension. Do I need to find a cabinet shop to get this odd size? Your help and/or suggestions are appreciated.
2 replies so far
View MT_Stringer's profile
MT_Stringer
3172 posts in 3259 days
#1 posted 05-17-2014 04:38 PM
You could cut a rabbit along the front edge of some 3/4 inch plywood that would fit the groove. Test fit then cut the other pieces to fit. Cut additional dados for the bottom and top or use cleats and glue or pocket screws…whatever you decide.
Good luck.
Mike
View Wickate's profile
Wickate
70 posts in 2822 days
#2 posted 05-17-2014 05:19 PM
I’d go with MT’s suggestion and use oversized ply and then cut it down to fit with a rabbit that’s the correct size to fit the slot. Good thinking MT_Stringer.
