Bathroom Fan to remove dust ?
Forum topic by Zuki posted 312 days ago 407 views 0 times favorited 11 replies Add to Favorites Watch
View Zuki's profile
Zuki
1230 posts in 974 days
312 days ago
Topic tags/keywords: zuki fan
I was thinking . . . how would a bathroom fan work to remove sawdust in the shop? I know that when vented to the outside it will suck the warm heated air out as well . . . but would it work at removing dust?
similar to this one – http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100066718&categoryID=500524
Im thinking it would probably clog up with dust as it is used to move moisture.
View John Ormsby's profile
John Ormsby
503 posts in 634 days
312 days ago
Bath fans are way to small to move the amount of air and dust in a shop. You will need a much larger fan or multiple fans to get good air movement.
-- Oldworld, Fair Oaks, Ca
View tenontim's profile
tenontim
1319 posts in 641 days
312 days ago
I have a small fan, about 80-100 cfm, that I run to help keep the fumes down when I’m finishing. It doesn’t move enough air to over ride the heater but will remove most of the fumes in a rather short amount of time.
-- Tim -- http://tmuli.com
View DaveH's profile
DaveH
372 posts in 675 days
312 days ago
For dust, this would be my minimum recommendation:
Grizzly Heavy-Duty Hanging Air Filter
Don’t imaging it would be too hard to sell the better half on the idea…After all it is a health issue. Dust collection and filtering was an easy sell for me.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
View PetVet's profile
PetVet
233 posts in 384 days
312 days ago
Hey Zuki, what I did was buy a cheap 20 inch fan, got for $17, and then I tape a 20×20 ” fan filter to the infeed side of it. You wouldn’t believe the amount of dust it collects! I run it any time I am in the shop.
-- Rich in Richmond
View David Freed's profile
David Freed
94 posts in 564 days
312 days ago
What PetVet said.
-- David, Southern Indiana
View treeman's profile
treeman
149 posts in 346 days
312 days ago
The best method I have found is to salvage a blower unit from a furnace/AC that has been replaced. Check your local heating and air places and ask them to save one for you. Once you have it; build a box to enclose it, size it to fit some standard furnace filters. Use filters in multiple and use an electrostatic filter in the mix. I also use a washable prefilter at the front of the filter stack as it takes the most abuse and filters out the large particles. This helps to make the more expensive electrostatic filters last longer.
I find this unit to outperform most commercial units and they are very inexpensive to make. Ths filters usually cost more than the rest of the unit. The unit I am currently using filters down to .3 microns.
View Woodchuck1957's profile
Woodchuck1957
950 posts in 661 days
312 days ago
A bathroom fan might work if your shop is no bigger than a coat closet, lol. In a double garage I have a cyclone dust collector, a air filtration unit hung from the ceiling and sometimes when sanding I also keep a box fan close by that I built some channel for a furnace filter to slide into.
View motthunter's profile
motthunter
2079 posts in 696 days
312 days ago
may work a bit until the motor gets caked with dust and stops working.
-- making sawdust....
View Zuki's profile
Zuki
311 days ago
LOL Woodchuck.
Yea . . . I didn’t think it would be a super idea. Just thought I would float the concept to get opinions on this el cheapo dust reduction system.
I think I’m going to look into petvets idea.
View SCOTSMAN's profile
SCOTSMAN
2244 posts in 482 days
311 days ago
if your reffering to airborne sawdust I have such a set up I made with underfelt carpet underfelt that is the wooly kind used as a set of filters.These are set up over my benchsaw it does work quite well actually but then I would never try to remove dust direct from a machine with it, and have big extractors for this twin bad type. In the air though over a dusty machine it works remember I have two in the unit push pull arangement it works very well.AQlistair
View RichardB's profile
RichardB
69 posts in 386 days
311 days ago
I got here late, but I’ll echo everyone else: NO
Fart fans can’t hardly get rid of stink, let alone shower steam! A commercial kitchen range hood might pull the dust, but it will suck all the heat out too. Look for an old squirrel-cage furnace fan, or even a cheap box fan like the others said.
