Saw that will cut curves
Forum topic by nate22 posted 05-17-2014 09:44 AM 1245 views 0 times favorited 6 replies Add to Favorites Watch
View nate22's profile
nate22
475 posts in 2780 days
05-17-2014 09:44 AM
What kind of saw should I use to cut curves with on bigger pieces so I don’t have to use my scroll saw. I’m going to use my scroll saw for smaller projects but I’m not sure what kind to use on bigger ones.
-- Gracie's wooden signs. Middlebury, In.
View Monte Pittman's profile (online now)
Monte Pittman
28163 posts in 2242 days
#1 posted 05-17-2014 09:58 AM
Bandsaw is best, jigsaw would be second
-- Mother Nature created it, I just assemble it.
View Jim Jakosh's profile
Jim Jakosh
20071 posts in 3010 days
#2 posted 05-17-2014 11:53 AM
Hi Nate. The band saw is the best for that. If you cutting a tight radius, you will need to check the chart to see the minimum radius you can cut for the width of the blade.
Jim
View NiteWalker's profile
NiteWalker
2736 posts in 2481 days
#3 posted 05-17-2014 01:03 PM
For bigger than what would fit on a bandsaw or scrollsaw, a jigsaw would be your best bet. It’s a great tool to have around anyway.
Don’t skimp on one; get a good one, and good blades, like bosch. The newer bosch jigsaws get good reviews, as does the makita, which I like. The makita also has an led. The new festool carvex jigsaws look pretty nice, but $$$$.
View Loren's profile
9947 posts in 3552 days
#4 posted 05-17-2014 02:12 PM
I use an older Festool Ps300 jig saw. It’s very smooth and
superior to a Bosch I had. The Festool has little guides
down close to the throat, kind of like band saw guides,
and they are made precisely. You can get a used on on
ebay.
Cutting curves in large piece on the band saw can be a bit
tricky. You can learn to do it and the saw cuts easier
than a jig saw, but it can be trickier to follow a line
closely on the band saw. With a jig saw you can get
right up on top of the line.
For milder contoured shapes, band saws can be set up
with a template copy jig. It’s real simple and can make
cutting out multiple parts a snap.
View Jim Finn's profile
Jim Finn
2618 posts in 2826 days
#5 posted 05-17-2014 02:15 PM
I use a hand held jig saw for cuts like this. I like my barrel grip Bosch with very fine (metal cutting) blades.
View kdc68's profile
kdc68
2638 posts in 2181 days
#6 posted 05-17-2014 03:26 PM
another vote for band saw and jig saw….
Another alternative to Loren’s suggestion is to create patterns that can be used over and over again from tempered hardboard. You use either one of these tools cut the pattern. Rough cut leaving the line then fine tune with sandpaper, files, or whatever you got for a perfectly smooth pattern. Use the pattern for lay out on your work piece. Rough cut the wood with either of these tools leaving the line. Apply pattern to wood with double stick tape and use a flush cut or pattern cutting router bit to create a perfect piece that matches your pattern
-- Measure "at least" twice and cut once
