HVLP
Forum topic by ScottM posted 05-16-2014 02:21 PM 1495 views 0 times favorited 17 replies Add to Favorites Watch
View ScottM's profile
ScottM
574 posts in 2021 days
05-16-2014 02:21 PM
I just returned from HF with a new HVLP spray kit. This is my first spray unit and I thought I’d give ths one a try based on the price. It has gotten pretty good reviews so I figured what the heck.
My question is really about cleanup. I’m just finishing a project that I was figuring to be a bear to poly finish with a brush so that’s why I popped on this sprayer. I’m going to spray water based poly. The can says 2 hours between coats. Do I, or should I, clean the entire gun between each coat or can I leave the remainder of the poly in the cup while I wait? Maybe just clean the needle and tip? Any thoughts would be helpful.
17 replies so far
View b2rtch's profile
b2rtch
4847 posts in 2922 days
#1 posted 05-16-2014 02:27 PM
If you wait your poly will set in the sprayer just as it will do on the wood.
Empty the reservoir and spray some clear water until clean.
At the end of the job take the whole thing apart and clean it really good.
-- Bert
View TheDane's profile
TheDane
5349 posts in 3537 days
#2 posted 05-16-2014 02:32 PM
When I am spraying water-borne finishes, I don’t clean between coats. Just make sure you do a thorough cleaning at the end of the day. I have an Earlex, but I would think the same applies to the HF unit you have.
ScottM
#3 posted 05-16-2014 03:15 PM
I don’t mind removing the needle and tip and cleaning those between coats. I just don’t want to have to empty the cup and then refilter and fill every 2 hours. I actually just finished a coat and I’m going to leave the cup as is with the remainder of poly in it, however, I did remove the needle and clean that. We’ll see how it goes. Thanks for the info and suggestions guys.
Gerry, what size needle do you use for water based finishes? The unit I got came with 3; 1.5, 1.8, and 2.0. I tried the 1.5 last night and it sprayed extremely light so I tried the 1.8 today. Just curious what others go too.
TheDane
#4 posted 05-16-2014 03:20 PM
The Earlex comes with a 0.08” fluid tip & needle … that is all I have ever used.
b2rtch
#5 posted 05-16-2014 03:47 PM
I had a Earlex (not anymore more).
It had several needles,I used the 1.6 for latex and other waterborne products
-- Bert
TheDane
#6 posted 05-16-2014 03:55 PM
The Earlex manual shows the needle sizes in SAE (0.04”, 0.06”, 0.08”,0.10”). The needle supplied with the unit I have (0.08”) is equivalent to a 2.0mm. I just check the viscosity, but haven’t had to thin any finishes and have gotten good results.
ScottM
#7 posted 05-16-2014 07:28 PM
I may try the 2.0mm needle next. I’m sort of experimenting with the drawers of some nightstands that I built and I’m getting some orange peel happening.
View InstantSiv's profile
InstantSiv
259 posts in 1469 days
#8 posted 05-16-2014 08:44 PM
I’ve run gallons and gallons and gallons of polycrylic through that harbor freight sprayer. That thing is a beast and still runs like a champ, I’ve had it over a year.
I just wipe the tip dry between coats with a paper towel, outside of needle/tip without taking it apart. Sometimes I forget and it’ll dry over so it’s just a matter of scraping it off with my finger nail.
I’ve forgotten to clean up at the end of the day sometimes and there’s no ill effects after sitting overnight, just the dried tip. I don’t suggest that but just my experience.
I’ve had the best luck with the middle size tip.
On the orange peel, is the layer thin or thick. I started out with a orange peel like surface. I would spray a small amount and make my passes slowly. Now I get glass like surfaces. I spray mine on thick enough to where it looks like the surface of water. It’s a little trial and error to get the right amount so practice. You want to open up the needle adjustment to spray a lot and make your passes really really quick. I do one pass from left to right and immediately go over that with a pass from top to bottom. There’s a balance between too little(orange peel) and too much(runs).
View NiteWalker's profile
NiteWalker
2736 posts in 2451 days
#9 posted 05-16-2014 10:06 PM
No need to clean between coats; just wipe the tip and you’re good.
For extended waiting periods, a piece of tape over the cup vent hole prevents the finish from hardening.
View Mainiac Matt 's profile
Mainiac Matt
7564 posts in 2203 days
#10 posted 05-16-2014 11:14 PM
I think the point that your missing is that exposure to air is required for the polycyclic to cure. Inside your cup and gun, it is not exposed to air.
I’ve never sprayed it, but I have brushed several gallons of it, and in my experience it dries a lot faster than two hours.
-- Pine is fine, but Oak's no joke!
View pintodeluxe's profile
pintodeluxe
5544 posts in 2687 days
#11 posted 05-16-2014 11:21 PM
I always drain the gun, and remove the needle and nozzle for a soak in thinner. Take the filter out as well, and drop it in the thinner (mineral spirits in this case). The tiny apertures in the nozzle quickly clog, and will affect spraying performance on the second coat. In fact, take the body of the gun and rest it in the thinner as well. This will keep the inner nozzle from clogging.
Use a pipe cleaner and solvent to clean the air vent in the top cap.
This entire operation takes 2-3 minutes, and the solvent is reusable (put some in a Tupperware container).
If you don’t do this, I guarantee the spray pattern will suffer at some point.
FYI, when you remove the needle, the fluid cup will drain. There is no way to keep fluid in the cup with the needle removed.
View dhazelton's profile
dhazelton
2657 posts in 2171 days
#12 posted 05-17-2014 12:33 AM
I wonder what would happen if you do what I do with a paint roller I don’t want to clean between coats – put it in the refrigerator.
runswithscissors
2603 posts in 1899 days
#13 posted 05-18-2014 07:40 AM
I have used my HF HVLP (the model with its own blower) with water based acrylic. Leaving the stuff in the gun overnight, or even longer, doesn’t seem to be a problem at all.
Shawn Masterson
1324 posts in 1823 days
#14 posted 05-18-2014 04:42 PM
+1 for leaving it. I use the 12.99 HF hvlp guns, and I leave have left it in as long as 48 hours. The 2 hour wait time is kind of odd to me. I use minwax latex poly? I get it from menards.
This past winter I was finishing the cabinets for my living room. I stoked up the wood stove and had it 110* in the shop. I sprayed it 6 fine coats with about 15 minutes in between Then I let it sit overnight with the temp slowly descending. In the morning (still 80) I hit it with some 320 to smooth it down and laid one final coat. The came out perfect. The high coat count will soften the edges, and give the finish a nice depth. I have done this on many projects and never had a problem. I have even lit the stove in the summer just to cook a finish on.
View Bill White's profile (online now)
Bill White
4821 posts in 3835 days
#15 posted 05-18-2014 09:31 PM
Which gun did you buy? Model, link?
Bill
-- bill@magraphics.us
