Has anyone used the Tomz Knife Massager to sharpen plane irons?
« back to Hand Tools forum
Forum topic by HarveyDunn posted 05-16-2014 01:51 AM 1962 views 0 times favorited 5 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1696 days
05-16-2014 01:51 AM
Has anyone used the Tomz Knife Massager to sharpen plane irons? If so, any thoughts/tips?
5 replies so far
View giser3546's profile
giser3546
179 posts in 1437 days
#1 posted 05-16-2014 05:41 PM
I have not, personally I use water stones and the Veritas honing guide. However I only use that because the Work Sharp 3000 hadn’t come out yet, which the Tomz seems quite similar to. If you could rig up some kind of guide to be sure you’re getting a good straight bevel and you have the right grits it should work.
-- "If you wait for it to rain, It will"
View hairy's profile
hairy
2655 posts in 3497 days
#2 posted 05-16-2014 07:16 PM
I have a Tomz, but haven't used it for that. I agree about a jig to hold the angle being the way to go. I made a platform that goes around the Tomz to extend the base to work from, it gives a bigger flat area for my Crocker jig. If I was to make another, it would go around 3 sides, leaving the switch end alone. So, I haven’t done it, but I think it can be done. Other things might be easier. One thing about Tomz, it runs at 33 rpm fixed speed.
-- My reality check bounced...
HarveyDunn
#3 posted 05-17-2014 01:03 AM
Thanks. I’ve constructed a platform and have a honing jig to hold the iron for the correct angle. I can’t decide what I should do about the back. Any suggestions?
hairy
#4 posted 05-17-2014 01:44 PM
I assume you mean the back of the iron? It’s flat? The way I hone a knife is to lay it flat and tilt it up about the thickness of a dime. I’d do a plane iron the same way, it’s a wide knife blade.
HarveyDunn
#5 posted 05-17-2014 02:11 PM
Yes – the back of the iron. It looks flat, but I don’t know how I would test it to confirm that it is “dead flat”.
I know that people sharpening plane irons on stones use “the ruler trick”, which sounds close to what you are saying: lay the back of the iron flat on the stone, cutting edge within 1/4” of one of the long edges of the stone. Then on the opposite edge of the stone they insert a very thin metal ruler under the iron. That has the effect of raising it a few degrees.
