| Forum topic by ShannonRogers | posted 309 days ago | 587 views | 0 times favorited | 11 replies | ![]() |
309 days ago |
Topic tags/keywords: workbench circular saw tips question I still have a few more laminations to glue on my bench, but I am already thinking about squaring up the ends of this 4” thick top. My circular saw doesn’t have the capacity to do this so I will have to attack it from both sides. Anyone has any tips for doing this accurately so I can get a straight and square cut? I will be cutting a tongue into the end later to join the end cap for the tail vise so it is imperative that the first end cut be straight and square. -- Check out my blog and podcast "The Renaissance Woodworker" at www.rogersfinewoodworking.com/blog |
309 days ago |
Call around and see if you can find a lumberyard or a cabinet shop that has a 12” radial arm saw. But then again, you don’t mention how wide the top is, so I don’t know if that would work or not. |
309 days ago |
Woodchuck, good thought, but the top will be about 28” wide and 8’ long weighing close to 250lbs. There has got to be an easier way. Pat may be on to something that I hadn’t thought of. -- Check out my blog and podcast "The Renaissance Woodworker" at www.rogersfinewoodworking.com/blog |
309 days ago |
4” is pretty thick, thats a tough decision. There are large circular saws, but they are about $500, and I don’t know who you would call that would own one that you could have them cut it. Maybe check a rental outfit and see if they have such a beast. |
309 days ago |
I had the same problem and got a good method from some forum posters. Use a straight edge guide and cut as deep as you can. Then turn it over and clamp the straight edge so that it cuts 1/16” past the first cut. Then use a pattern bit to flush the longer side up to the first cut. One note though – I ended up buying a new circular saw to do this. The old one (a CMan) would not adjust to perpendicular to the plate. It was off by a couple degress due to the motor housing hitting the plate before it reached square. A number of the ones I looked at had similar problems. So double check your CS squareness before cutting. -- Use the fence Luke |
309 days ago |
I use a homemade circular saw guide whose edge references the actual blade cut. Having that, it’s a simple job of laying out the cut lines and then clamping the guide dead-on before making the cut. With a deep cut such as you have, I always make a shallow scoring cut before going full depth in order to circumvent any chip-out. If you go this way, make sure your circular saw is tuned, that the blade is sharp and that you’re making a cut that’s square to the table top. I used this method on my bench top which is 3 inches thick, but I made housed tenons for a breadboard end-cap instead of leaving the end grain exposed. Good luck. Always, -- "Imagination is more important than knowledge" -- Albert Einstein |
309 days ago |
I would probably just do the cut by hand myself if I didn’t have -- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html |
309 days ago |
I had exactly the same problem last year when I built my bench, Doug S. did almost what I did but I think his idea of the flush trim bit is one better. I used a straight edge and set my Circular saw to max depth and squared it up. I crosscut the bench top and then used the kerf left behind by the C.S. as a guide and finished the cut with a hand saw. Came out really well with only a small amount of cleanup work with a sanding block. Prevented me from having to man handle the top by myself, mine is 3 1/2” thick by 7’ long and very heavy, not to mention awkward if working alone. Anyway, that was my solution, hope it helps Chris -- So Much Wood - So Little Time! -- |
309 days ago |
309 days ago |
How about renting a large circular saw? -- Ellen on Cape Cod |
308 days ago |
KnotHead has it. I use this method to do quick resawing sometimes- If I used the router bit method it would be only for final trimming -- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html |
308 days ago |
If you’ve got a few bucks burning a hole in your pocket, you could get one of these: http://www.praziusa.com/beamcutter.html |
| Forum | Topics |
Woodworking Skill Share
2898 |
3913 |
256 |
941 |
221 |
Woodworking Trade & Swap
616 |
Coffee Lounge
2368 |
LumberJocks.com Site Feedback
522 |
