need help for sealing bark
Forum topic by JayTay posted 05-16-2014 12:02 AM 763 views 0 times favorited 2 replies Add to Favorites Watch
View JayTay's profile
JayTay
15 posts in 1565 days
05-16-2014 12:02 AM
ok here’s the deal. i got 1st cut cedar it has bark on one whole side of the board. im using it as siding for an outside project. i want to seal/treat it to maintain the bark. would it be best to just hit it with a deck sealer like product or go with something else or nothing at all?
thanks for any help.
2 replies so far
View bigblockyeti's profile
bigblockyeti
5134 posts in 1742 days
#1 posted 05-16-2014 01:55 AM
You could hit it with deck sealer, but in my experience, wood that’s exposed to the elements will shed it’s bark eventually. Some species take longer than others and the sealer will certainly help delay the inevitable, but not completely prevent it. I’d have a plan for when it does start coming off, whether in two years or ten.
View EPJartisan's profile
EPJartisan
1118 posts in 3147 days
#2 posted 05-16-2014 02:22 PM
I might recommend soak the bark edge with wood hardener.. mini wax makes the one i use, expensive though. Deck sealer won’t harden the cambium layer, so I would treat it like rotted wood… or that thin layer may decay… but for outdoor shingles I might even add a coat of marine spar after. to resist the sheering of the bark from heat, sun, rain, and dry weather. :)
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
