Is anyone out there running AutoCAD ???
Forum topic by johnhutchinson posted 05-15-2014 09:09 PM 1159 views 0 times favorited 13 replies Add to Favorites Watch
View johnhutchinson's profile
johnhutchinson
1243 posts in 1834 days
05-15-2014 09:09 PM
Topic tags/keywords: design question cad
I am, but I have a problem. (For now, I’d like to limit the discussion to my AutoCAD problem)
I was running AutoCAD 2007, but due to a computer problem I’m now running AutoCAD 2000. I can’t open my 2007 files in 2000 because they were produced by an “incompatible version” of AutoCAD. Grrr
Does anyone know how to dumb 2007 files down to 2000?
HELP !!!
-- John - Central Ohio - "too much is never enough"
13 replies so far
View mramseyISU's profile
mramseyISU
555 posts in 1750 days
#1 posted 05-15-2014 09:14 PM
Sorry but with all the CAD systems I’m familar with (AutoCAD included) you can’t open future versions just past ones. I think you’re hosed unless you can get access to AutoCAD 2007 or newer and then you can save them down as the 2000 release file format.
Plan B would be to go get draftsight it’s a free autoCAD clone released from the parent company of SolidWorks that might do the trick for you.
-- Trust me I'm an engineer.
View Richard's profile
Richard
1922 posts in 2895 days
#2 posted 05-15-2014 09:24 PM
Like mramsey said , find someone that has AutoCAD 2007 or newer and have them opem them and resave them in AutoCAD 2000 format.
View pmtottawa's profile
pmtottawa
15 posts in 2188 days
#3 posted 05-15-2014 09:49 PM
there are 2 ways you can open them:
1- you can use autocad 2007 and use the save as option to save to a lower autocad version. This method allows you work on the lowered version file.
2- download a dwg viewer. This method allows you view, print and possibly annotate your file, but you will not be able to open it in autocad 2000.
pmt
View patcollins's profile
patcollins
1687 posts in 3069 days
#4 posted 05-15-2014 09:53 PM
Are any of them three dimensional?
I have access to Autocad LT 2010, which is only 2D.
View darinS's profile
darinS
713 posts in 3071 days
#5 posted 05-15-2014 09:54 PM
JOHN
If you want, PM me the files and I will see if I can save them down to a 2000 compatible.
-- They say many people die because of alcohol. They never realized how many of them are born because of it.
View crank49's profile
crank49
4032 posts in 3175 days
#6 posted 05-15-2014 10:00 PM
http://www.cadwizz.com/
Here is a link to a free trial version of a drawing viewer.
This viewer has the ability to save Autocad files as different versions or even convert them to other formats.
View bigblockyeti's profile
bigblockyeti
5288 posts in 1925 days
#7 posted 05-15-2014 10:43 PM
I know that’s frustrating and from what I understand, nothing you can do about it, at least within the capacity of Autodesk software. I’ve had the same problem creating new excel spreadsheets and trying to open them with older software. I now make sure I save certain new stuff as an excel 97-03 workbook.
johnhutchinson
#8 posted 05-15-2014 11:11 PM
Thanks, guys. I think I’ve found a conversion volunteer.
LumberJocks, as always, ROCKS !!!
View changeoffocus's profile
changeoffocus
467 posts in 1821 days
#9 posted 05-15-2014 11:42 PM
You might try down loading a trial copy of latest and greatest ACAD and use that to save your files backward to 2000.
I think the demo is full featured.
That way you could do it in house until you get 2007 back up, you’d have 30 days of use.
View lanwater's profile
lanwater
3111 posts in 3138 days
#10 posted 05-16-2014 05:28 AM
I run into this:
DWG TrueView
TrueView is a FREE (we all like free, aren’t we?) application you can download from Autodesk site. It’s actually a DWG viewer. You can open any DWG files with it. But you should know that you can use TrueView to save a file back to older version. To beauty of TrueView for me, you can batch convert all files in a folder.
If you have older version and can’t open a DWG, you can use TrueView to convert files you receive to your owned version. You just need to download it here: http://autodesk.com/dwg
-- Abbas, Castro Valley, CA
View PaulHWood's profile
PaulHWood
445 posts in 2457 days
#11 posted 05-16-2014 11:51 AM
What lanwater said is correct, you may lose some advanced features when saving back to an older version, but woodworking plans are usually quite simple.
-- -Paul, South Carolina Structural Engineer by trade, Crappy Woodworker by choice
johnhutchinson
#12 posted 05-16-2014 02:24 PM
Once again, I’m overwhelmed by the kindness and helpfulness of the folks on LumberJocks.
THANK YOU ALL VERY MUCH !!!
Yesterday I was in a real pinch, and today I’m a happy camper with the converted files I need.
And I’d like to send a special shout-out to Bob Current. He jumped on the case and the files were sitting in my inbox this morning.
Now about that $10,000 I’d like to “borrow” ... :)
mramseyISU
#13 posted 05-16-2014 03:15 PM
If you’re looking for a new version of “autoCAD” check out draftsight. We have a couple old time autoCAD users who can’t tell the difference between them.
http://www.3ds.com/products-services/draftsight/overview/
