Craftsman 113.298240 restoration
Forum topic by jlabos posted 05-15-2014 02:17 AM 1201 views 0 times favorited 9 replies Add to Favorites Watch
View jlabos's profile
36 posts in 1408 days
05-15-2014 02:17 AM
Topic tags/keywords: question tablesaw refurbishing
The Craftsman saw I am getting up and running again has sticky trunnions gears. I have some Johnson wax that I will be using on the surface of the saw once I finish sanding it. I have heard that you can use the Johnson wax on the trunnion gears as well. Has anyone done this? Does it work well? Does it also help with cleaning up the the area?
9 replies so far
View TiggerWood's profile
271 posts in 1541 days
#1 posted 05-15-2014 03:04 AM
I use wd40 with steel wool to clean everything and then use Johnson’s paste wax on all sliding parts. I’m sure there are lubricants that would work better but I like the surfaces being dry. Works fine for me.
View TheFridge's profile
9097 posts in 1421 days
#2 posted 05-15-2014 03:05 AM
I’ve heard lithium dry grease? Or something works well on trunnions, but paste wax is awesome for table and everything else.
The paste wax is pure awesome in my experience. I took a table saw and a jointer with a lot of surface rust, sanded down, cleaned pretty good with mineral spirits (leaves no residue), then put a few coats on over the course of a week or 2.
I live in louisiana and I’ve had zero probs.
View Paul's profile
721 posts in 1500 days
#3 posted 05-15-2014 03:36 AM
grease them, paste wax will wear off one full blade tilt and will leave metal on metal with no lube.
View scribble's profile
150 posts in 2135 days
#4 posted 05-15-2014 10:40 AM
I’m in the process of rebuilding a c*man saw as well currently and a member on another board suggested making up a wax/graphite block.
I personally have not tried it yet but am going to attempt to make a block here this weekend to give it a try.
He used it on the sub assembly sliding portions, the trunnion slides, and the jack shafts for tilt and lift. It looked like it moved well when finished, just not sure about longevity but I have used graphite on things were we worked for awhile that were extremely sandy and it works great.
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
View knotscott's profile
7938 posts in 3310 days
#5 posted 05-15-2014 11:22 AM
Typical machine grease is not recommended, because it attracts saw dust readily and you wind up with a caked up mess. Paste wax applied with a tooth brush will work, but will wear off faster than some other methods. White Lithium spray on grease, as recommended by Wood Mag works well, and is easy to apply….it sprays on wet, then dries so it doesn’t attract dust. Teflon spray is said to work very well, but is something that I haven’t tried yet….maybe when my white lithium spray runs out, I’ll give it a go.
#6 posted 05-16-2014 03:00 AM
Thanks for the advice. I plan is to get some Blaster white lithium grease at Home Depot.
View woodchuckerNJ's profile
1263 posts in 1569 days
#7 posted 05-16-2014 03:47 AM
Try the blaster teflon.. I used it and am happy with it.
-- Jeff NJ
#8 posted 05-17-2014 01:13 AM
Picked up some Blaster Dry Lube PTFE (teflon) tonight. I will try to find some time tomorrow to spray some on.
#9 posted 05-20-2014 04:37 AM
The Blaster Dry Lube worked great. I recommend the product to anyone else trying to restore an old trunnion that has been sitting for a long time. It dries nicely and still loosens the gears up.
