G0690hits insert when tilted 45 degrees.
Forum topic by mabisme posted 05-14-2014 10:52 PM 828 views 0 times favorited 5 replies Add to Favorites Watch
View mabisme's profile
mabisme
13 posts in 1448 days
05-14-2014 10:52 PM
I have a new G0690, the blade and fence to miter slot alignment is good. when I made my first 45 degree cut the blade would just barley nick the throat plate. I installed a zero clearance insert to be able to make the cuts but want to know if I missed something in the setup?
-- Mark , Northern Cali.
5 replies so far
View Mark Kornell's profile
Mark Kornell
1169 posts in 2494 days
#1 posted 05-15-2014 02:45 AM
No, you haven’t missed anything. Even if the tilt mechanism on a saw is perfect, the cross section of the blade where it goes through the top is wider when the blade is at 45 than when it is straight up (by a factor of approximately 1.4 if you care about the math). So if your ZCI was cut for 0, the blade will definitely nick the insert when at 45.
-- Mark Kornell, Kornell Wood Design
View TheFridge's profile
TheFridge
9249 posts in 1449 days
#2 posted 05-15-2014 03:10 AM
It’s zero clearance at 90*. Negative clearance after that.
mabisme
#3 posted 05-15-2014 10:58 PM
Sorry, I didn’t make myself very clear (I am new to this) It was hitting the metal stock insert that came with the saw. I made a zero clearance 45 degree insert so I could make the cuts. ( I re-read my original post and it was worded wrong.)
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1597 days
#4 posted 05-15-2014 11:54 PM
Yea that’s not right.
Did you move your top?
I’ll bet when you setup your top, you worried about whether it was parallel to the miter, but did you make sure the blade was where it needed to be? You probably need to re-zero your table top, and move it to the left a 1/16 to avoid the throat plate. The other thing is you can just not use the stock plate, and make another plate for tilting, that has that clearance. That’s what I would do. I don’t like the metal plates, a nick is not good, as it will destroy the carbide.
-- Jeff NJ
mabisme
#5 posted 05-16-2014 11:38 PM
No, I didn’t have to move the top, it was pretty much dead on to the miter slot from the box. I plan on all zero clearance inserts eventually. Just waned to make sure I didn’t miss something in set up. Luckily I caught it before it damaged my blade. Thanks for your inputs.
