Problems with a new jig
Forum topic by Gary posted 01-18-2009 06:28 AM 980 views 0 times favorited 8 replies Add to Favorites Watch
View Gary's profile
Gary
9386 posts in 3671 days
01-18-2009 06:28 AM
I have a Rigid tablesaw. I bought a heavy duty tennoning jig from Rockler. I’ve been working on it for two days and can’t get it to adjust correctly. Anyone had any experience??
8 replies so far
View juniorjock's profile
juniorjock
1930 posts in 4003 days
#1 posted 01-19-2009 02:33 AM
What’s it doing?...... or not doing?
- JJ
View Gary's profile
Gary
#2 posted 01-19-2009 02:48 AM
Had to move the miter gage bar to the ourside slot to get the vertical support plate t zero out. When it touches the blade, the pointer can’t be adjusted closer that 1/2 inch.
View motthunter's profile
motthunter
2141 posts in 4037 days
#3 posted 01-19-2009 03:07 AM
hard to help without photos.. are you sure that you have it mounted to the right side?
-- making sawdust....
juniorjock
#4 posted 01-19-2009 03:08 AM
I’m not sure. I’ve got a Grizzly. It has several adjustments on it. All have locks that have to be loose before things will move. There’s one adjustment for getting the jig close to where you need it and another micro adjustment. I’m not familiar with your jig, but on the Grizzly, I had to dis-assemble the entire jig, clean all the grease off everything, and then put it back together before it would work. Wish I could be of more help.
-JJ
juniorjock
#5 posted 01-19-2009 03:09 AM
motthunter is right, some photos would help a lot.
- JJ
View Gary's profile
Gary
#6 posted 01-19-2009 04:32 AM
Probably right. I’ll take some pix and show the problem. My wife thinks I’m just making a dry run for altzheimers.
View Gary's profile
Gary
#7 posted 01-20-2009 02:32 AM
Hey, thanks.. I’ll check it out to see if that’s the same model. That may be the fix…..
View Gary's profile
Gary
#8 posted 01-21-2009 02:39 AM
bentlyj, thank you soooo much. That was it. I never would have figured that out. I appreciate ya much! g
