Problems with epoxy inlays
Forum topic by JReed3 posted 05-14-2014 12:22 AM 1425 views 1 time favorited 8 replies Add to Favorites Watch
View JReed3's profile
JReed3
81 posts in 2335 days
05-14-2014 12:22 AM
I have doing several plaques recently using epoxy but I have started having a problem. After routing out the plaque, I have sprayed the immediate area with lacquer to help seal the wood around the routed area. I have also used wax around the area and both techniques have worked alright without any bleeding into the grain around the inlay.
The last two plaques I did out of maple where terrible. Lots of bleeding around the inlayed area. Theres so much bleeding in the out lying area, it cannot be sanded out, because the bleeding has gone so deep.
I did some testing on a scrap piece of maple and did the sealing a little differently. At the time I sprayed the area around the pocket, I also sprayed down into the pocket thinking the epoxy was wicking through the sides. I then waxed around the immediate area and put the epoxy in.
Same problem.
Any suggestion to stop this?
8 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3676 days
#1 posted 05-15-2014 05:33 AM
Is the wicking just along the grain or is it wicking across the grain also? How thin is the epoxy you are using?
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1598 days
#2 posted 05-15-2014 07:04 AM
What was the wood that didn’t have the problem?
Have you tried dewaxed shellac or zinsser sealcoat instead of lacquer?
Maple is such a dense closed grain wood, I can’t imagine it being worse than lets say oak or walnut.
I would test again, using shellac. try 2 different approaches, spray into, and brush into. wait an hour or 2 for it to cure.
-- Jeff NJ
View bigblockyeti's profile
bigblockyeti
5090 posts in 1684 days
#3 posted 05-15-2014 12:16 PM
Do you have any pictures showing what’s happening?
JReed3
#4 posted 05-15-2014 11:35 PM
1. Is the wicking just along the grain or is it wicking across the grain also? How thin is the epoxy you are using?
When I look at it, I can see it down in the grain running with the grain. I’ve seen it in some places and wonder how it got there. There was nothing around the area for it to even be there. The epoxy is about like syrup. Not runny at all. I’m using System 3 and use a scale to measure out the resin and hardener. No problem with the setting up.
2. What was the wood that didn’t have the problem? Have you tried dewaxed shellac or zinsser sealcoat instead of lacquer?
So far it is only with maple. No issue right now with mahogany. These are the only two woods I’ve been using. I haven’t tried the shellac or zinsser. I think I’ll do a test piece and see what happens.
3. Do you have any pictures showing what’s happening?
This photo shows whats happening. There was a pretty good coating over everything. The light color on the black epoxy is just dust from the trash can.
Mark Shymanski
#5 posted 05-16-2014 02:24 AM
So what I think I am seeing is seeping along the grain and not across. This suggests to me that it is capillary action along the fibers that is pulling the epoxy up. Are you thickening the epoxy? Mind you even if you were the epoxy may preferentially be drawn up the fibers instead of adhering to the thickeners…. Since it seems the epoxy is too thick to absorb across fibers that a barrier is needed to fill or block the paths being taken by the epoxy. Could you precoat the grooves with clear epoxy to allow the capillary action to draw up uncoloured epoxy which, after hardening, would prevent the next coat of coloured epoxy from being drawn up?
View JAAune's profile
JAAune
1786 posts in 2280 days
#6 posted 05-16-2014 02:54 AM
I spray about three or four light coats of dewaxed shellac over everything including inside the routing. After that, I’ll prep inside the grooves with clear epoxy until it looks like it’s not soaking in. The excess epoxy gets toweled out then I start with the colored stuff.
I also use a toothpick or dental pick to put epoxy inside the grooves to avoid getting too much on the surface of the wood.
Oh yes…
Scrape the excess epoxy off. If you sand it, you’ll just embed colored dust into the wood. After everything is scraped level, you can do light sanding but the dust has to be wiped off frequently.
JReed3
#7 posted 05-16-2014 10:53 AM
1. Are you thickening the epoxy?
No thickening agent being used.
2. Could you precoat the grooves with clear epoxy to allow the capillary action to draw up uncoloured epoxy which, after hardening, would prevent the next coat of coloured epoxy from being drawn up?
I haven’t used epoxy yet in the grooves. If I pre coat the grooves with clear epoxy, should I then come back with the color before it dries?
JAAune
#8 posted 05-16-2014 11:38 AM
You can apply the colored epoxy before the clear dries. All you’re doing is making sure that any wood that’s not sealed off by the finish is saturated with clear before the color goes in.
Just be sure to use slow set epoxy and wait 15 minutes after applying the clear to make sure it’s done soaking in. If you see dry spots you’ll need to apply more clear then wait another 15 minutes. Once the finish stops soaking in just wipe out the excess before it gets too tacky.
