Finish to use on outdoor SPF bench?
Forum topic by Bergman posted 05-14-2014 12:07 AM 1204 views 1 time favorited 3 replies Add to Favorites Watch
View Bergman's profile
Bergman
9 posts in 1742 days
05-14-2014 12:07 AM
So it’s probably not the best option of wood, but I am making a “coopers bench” for my bow building. The problem I have is that I don’t have anywhere indoors at the moment to put it. It won’t even have a roof to block the rain. (a quick Google for coopers bench will show you what it is if not sure)
Now, I’m using plain SPF lumber from Home Depot. I do not expect this bench to last very long, It’s more of a prototype. I’d like it to be bale to last a couple years if possible, but I don’t have a lot of experience with woodworking and especially with prepping stuff for outdoors. Mostly just whittling and I built an English longbow. Gotta start somewhere :)
Anyways, I don’t know what to finish this bench with, not even sure if this thing lasting a couple years is realistic. I will definitely be staining it, already picked out a Minwax stain I’ll be using. As for the finish I don’t really know. I’ve heard of Epifanes varnish being used on outdoor benches and working well.
Any suggestions at all would helpful. Does it matter how many coats of stain I should put on? If anyone suggests anything, could you also suggest how to apply it? eg. stain it, varnish, sand it after x amount of time, varnish again, how many coats etc.
Thanks in advance!
3 replies so far
View mesquite22's profile
mesquite22
42 posts in 2872 days
#1 posted 05-14-2014 12:14 AM
http://www.hempshield.net/ this is what I use
View Monte Pittman's profile
Monte Pittman
30062 posts in 2540 days
#2 posted 05-14-2014 12:46 AM
I use a Spar Urethane.
Bergman
#3 posted 05-16-2014 09:30 PM
Thank you, Cannot get hempshield anywhere around here (Ontario) as far as I know. As for spar urethane, should Mixwax Helmsman clear satin do the trick? Any experience?
