Face Joining
Forum topic by mvh posted 313 days ago 182 views 0 times favorited 6 replies Add to Favorites Watch
View mvh's profile
mvh
17 posts in 384 days
313 days ago
I was wondering if there is a length limit, say “x inches”, that a jointer with “y inches” of bed length can joint/face plane to get bows out of wood? The basis of my question is that if I have a 7’ long board with a bow in it, can it be face jointed straight with a 45” bed? I would think not since the begining of the board which has been jointed would be off the outfeed which might change the angle/pitch of the board approaching the knives? Am I way off base Thanks for any replies.
View juniorjock's profile
juniorjock
790 posts in 662 days
313 days ago
This is just a guess on my part (and I’m looking forward to see what the other LJs say) I’m saying that you should be able to do it. Like I said, this is a guess. don’t take my word for it. Looks to me like you’d eat up some wood, but eventually, you could join it.
-JJ
-- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood.
View John Ormsby's profile
John Ormsby
503 posts in 634 days
313 days ago
It can be done easily. I often joint boards 12’ to 14’ long with a 6 1/2’ long jointer. The jointer tables Must be aligned very well and getting the technique down. I can go right to glue up or any other process with nice crisp straight edges.
-- Oldworld, Fair Oaks, Ca
View jeffthewoodwacker's profile
jeffthewoodwacker
487 posts in 701 days
313 days ago
Should be no problem if your joiner is will tuned up and you use the proper technique. Take light cuts to start with.
-- Those that say it can't be done should not interrupt those who are doing it.
View ShannonRogers's profile
ShannonRogers
370 posts in 685 days
313 days ago
This can be done. I rely on a couple of roller stands place on infeed and outfeed side set to the exact height of the corresponding table. I just jointed a bunch of 10’ stock on a 49” jointer. Yes it would be much easier with a longer jointer bed, but not in the cards right now.
-- Check out my blog and podcast "The Renaissance Woodworker" at www.rogersfinewoodworking.com/blog
View Gene Howe's profile
Gene Howe
334 posts in 325 days
312 days ago
My method is to set the board on the jointer so that the height of the bow is directly over the cutters. Then joint the trailing end. Flip the board and do it again…and again…etc. Until the bow is barely nicked by the cutters. Then run the full length.
Works for me.
-- Gene
juniorjock
312 days ago
That’s a good idea Gene.
- JJ
