Finish for aspen while keeping it white?
Forum topic by LiveEdge posted 05-13-2014 10:05 PM 2050 views 1 time favorited 14 replies Add to Favorites Watch
View LiveEdge's profile
LiveEdge
571 posts in 1526 days
05-13-2014 10:05 PM
Topic tags/keywords: aspen finish white
Any tips on the best way to protect aspen while keeping it as white as possible? Spray on lacquer? It will be for a jewelry box so heavy use or adverse conditions are not an issue.
14 replies so far
View NiteWalker's profile
NiteWalker
2736 posts in 2482 days
#1 posted 05-13-2014 10:15 PM
You want a water white clear coat.
Crystalac super premium and general finishes enduro clear poly are two excellent choices. Crystalac is hard to get at the moment so I switched to the enduro clear poly. It will probably be my go-to finish from now on.
Both clear coats mentioned above dry crystal clear and stay that way, so no color change.
Both are waterborne, so you also get the benefits of low voc, easy clean up and fast drying times.
View SuperCubber's profile
SuperCubber
1015 posts in 2190 days
#2 posted 05-14-2014 01:08 AM
+1 for water-based. I’ve used GF water-based poly and it is crystal clear.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View Clint Searl's profile
Clint Searl
1533 posts in 2267 days
#3 posted 05-14-2014 01:30 AM
Rattlecan lacquer. It’s a no-brainer.
NiteWalker
#4 posted 05-14-2014 04:05 AM
Count, I was under the impression lacquer yellows over time?
View Finisherman's profile
Finisherman
227 posts in 1755 days
#5 posted 05-14-2014 05:26 AM
A waterborne finish or a water-white CAB lacquer would work well here
View Rick_M's profile
Rick_M
11109 posts in 2285 days
#6 posted 05-14-2014 06:36 AM
Lacquer is color neutral if you want it to stay white.
-- http://thewoodknack.blogspot.com/
View Monte Pittman's profile
Monte Pittman
28180 posts in 2244 days
#7 posted 05-14-2014 06:38 AM
Water based poly from here also
-- Mother Nature created it, I just assemble it.
View pintodeluxe's profile
pintodeluxe
5567 posts in 2719 days
#8 posted 05-14-2014 04:52 PM
I would use clear shellac, which imparts almost no color to poplar. I think aspen would finish equally well with clear shellac.
You could also try non-yellowing lacquer such as Rudd Duracat.
http://lumberjocks.com/reviews/3861
View Underdog's profile
Underdog
1055 posts in 1941 days
#9 posted 05-14-2014 04:56 PM
White Paint.
Seriously. Really.
That’ll keep it white.
-- "woodworker with an asterisk"
View MalcolmLaurel's profile
MalcolmLaurel
284 posts in 1528 days
#10 posted 05-14-2014 04:57 PM
I’d pick clear shellac too.
-- Malcolm Laurel - http://MalcolmLaurel.com
LiveEdge
#11 posted 05-14-2014 04:59 PM
Ah, the answer’s clarity is stark. All I need to do is use water based poly, lacquer, shellac, or paint. I can’t go wrong! :) I’ll probably use water-based poly since I have some and have a little experience with it. Now I just have to build the box…
View woodchuckerNJ's profile
woodchuckerNJ
1253 posts in 1539 days
#12 posted 05-14-2014 05:08 PM
Waterbased poly. Clear, easy to apply
-- Jeff NJ
View Warner's profile
Warner
33 posts in 1487 days
#13 posted 05-16-2014 08:51 PM
What would you use to keep the wood as white as possible on an exterior application where it will see heavy use?
-- Flint Hills, Kansas
View shampeon's profile
shampeon
1775 posts in 2089 days
#14 posted 05-16-2014 10:10 PM
Nitro lacquer will yellow over time, yes. Acrylic lacquer won’t as easily.
