trouble while replacing drive belt on Delta LA200 lathe
« back to Woodturning forum
Forum topic by 480gabe posted 05-12-2014 07:07 PM 937 views 0 times favorited 1 reply Add to Favorites Watch
View 480gabe's profile
480gabe
1 post in 1651 days
05-12-2014 07:07 PM
I replaced the belt on my lathe and thought everything was going fine. After putting everything back together and moving the tail stock up and tightening my project into place, the spindle and all kept moving left until the belt pulley was pushed against the side and wouldn’t turn. I tried taking it back apart and following the instructions over and over and over and still have the same problem. Any ideas out there??
1 reply so far
View joek30296's profile
joek30296
53 posts in 3042 days
#1 posted 05-12-2014 11:07 PM
Did you tighten the set screw in the pulley? I have that same lathe and if IIRC the pulley should bottom out on a shoulder on the right end of the shaft. Plus, there should be a flat spot on the shaft that the set screw rests on.
Try these things and let us know if that solves your problem. If not I’ll pull mine apart and take some pictures.
-- "There are two theories to arguing with a woman....neither of them work"
