Shelf for Displaying Plates
Forum topic by Dave Rutan posted 05-12-2014 06:00 PM 1028 views 0 times favorited 5 replies Add to Favorites Watch
View Dave Rutan's profile
Dave Rutan
1707 posts in 2187 days
05-12-2014 06:00 PM
Topic tags/keywords: question shelf
I need to put a dado in a shelf so that plates may be displayed on it. Question: how far from the wall should the dado be made and how wide should the dado be?
Thanks,
Dave
-- Ni faru ion el ligno!
5 replies so far
View bandit571's profile
bandit571
20005 posts in 2682 days
#1 posted 05-12-2014 06:02 PM
I used to use a 1/4” round nosed bit. Groove was about 3/4” to 1” away from the wall.
View ChefHDAN's profile
ChefHDAN
1062 posts in 2848 days
#2 posted 05-12-2014 07:43 PM
Dave, I did many at 1” from wall edge with a 1/2” core box bit, only ever had a problem when my wife wanted to put up a 20” platter, regular 10” to 11” plates will lean and stay put.
View Oldtool's profile
Oldtool
2622 posts in 2190 days
#3 posted 05-12-2014 07:47 PM
Dave,
I have several books with dimensional drawings of early American period furniture, two of which show:
Half inch wide by 1/4” deep, 3” out from the back, and
1/2” wide by 1/4” deep, 3.75” out from the back.
If you have the plates, press up against a flat surface & measure the depth, add 1/2” or 3/4” so the plate leans back. Then, measure the plate rim to see if you should use 1/4” or 1/2” wide slot.
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
Dave Rutan
#4 posted 05-12-2014 07:53 PM
Thanks for the replies so far, keep ‘em coming, just in case.
@ Oldtool, In this case I don’t have the plates. The shelves (2) are a project for my Pastor who is painting his kitchen and ‘adjusting’ his storage solutions. I’ll be milling this dado tonight and installing the shelves tomorrow.
Dave Rutan
#5 posted 05-12-2014 09:23 PM
The customer is always right. I decided to call my Pastor and he said that the ‘groove’ in his china cabinet is about 1 1/2 inches from the back. I did a test on a scrap of wood and tried that out using my biggest and smallest ceramicware. They were all held stable and rested against my wall well.
So I set things up and made the stopped dado at 1/2 inch wide and a pinch over 1/4 inch deep. It looks good and I’m happy. I also ran a Roman Ogee bit over the front and side edges (on the under side of the shelves. That makes them look more like a shelf than just a board on the wall. Tomorrow the install!
