Bi-metal bandsaw blades
Forum topic by bigblockyeti posted 05-12-2014 02:31 PM 1443 views 0 times favorited 14 replies Add to Favorites Watch
View bigblockyeti's profile
bigblockyeti
5170 posts in 1807 days
05-12-2014 02:31 PM
Is anyone using bi-metal blades designed for cutting metal on their wood cutting bandsaw with success? I checked out the Starrett Intenss bi-metal blades on Amazon and the price seemed reasonable. With 10tpi on a 1/2” blade I’m just wondering how it would perform at the much high blade speeds of a wood cutting bandsaw.
14 replies so far
117179 posts in 3663 days
#1 posted 05-12-2014 02:35 PM
I have tried many but after 25+ years contracting I prefer Milwaukee
E-bay has the best price
http://www.ebay.com/itm/milwaukee-sawzall-blades-48-01-9182-/321399563849
View b2rtch's profile
b2rtch
4862 posts in 3134 days
#2 posted 05-12-2014 02:55 PM
I use bi-metal band saw blades, made by my local supplier.
I think that the material Is s Leenox.
-- Bert
View Bill White's profile
Bill White
5011 posts in 4046 days
#3 posted 05-12-2014 04:34 PM
You sure can mess up a good wood cutting bandsaw by cutting metal. It will cut too fast, and you’ll get metal swarf in the tires.
Even though my 0555LX has the dual speed feature, I would be hesitant to cut metal with it.
Just a thought.
Bill
-- bill@magraphics.us
#4 posted 05-12-2014 04:58 PM
Boy oh boy looks like I didn’t read the original post well enough ,sorry about that.
View MrRon's profile
MrRon
4928 posts in 3330 days
#5 posted 05-12-2014 05:19 PM
Do you want to cut metal or wood on your band saw? If metal, then the answer is maybe. You could cut thin aluminum sheet, ( I wouldn’t recommend it)but large pieces of metal; not a good idea. If you want to cut wood with a bimetal blade, it should work ok. I think the teeth would get clogged quickly. The teeth set is different. metal cutting blades have a wavy set while wood cutting blades have an alternate tooth set.
b2rtch
#6 posted 05-12-2014 05:38 PM
I use a wood-cutting bi-metal blade
-- Bert
bigblockyeti
#7 posted 05-12-2014 05:57 PM
I’m wanting to cut wood, I know better than to cut metal with such a high blade speed, especially when neither the blade or the saw would do well with that setup.
Bill White
#8 posted 05-12-2014 06:22 PM
Guess I didn’t fully understand your original post. Sorry.
I have not used bimetal blades, but my supplier has suggested them for production work.
Having said that, a 10tpi blade should be used for finer work. Wouldn’t do well for resawing (but you knew that).
Bill
View Surfside's profile
Surfside
3389 posts in 2260 days
#9 posted 05-12-2014 09:08 PM
Would your saw burn up the bi metal blade? Wood band saws run fast. I’ve never tried so I’m not sure how to make it work.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View gfadvm's profile
gfadvm
14940 posts in 2776 days
#10 posted 05-13-2014 12:55 AM
By far the best resaw blade I have ever used is the 3/4”, bi-metallic, 2-3 TPI from Timberwolf.
View Phil53's profile
Phil53
90 posts in 3708 days
#11 posted 05-13-2014 01:13 AM
I have been using a 1/2” “Timber Wolf” bi-metal blade from http://www.suffolkmachinery.com/index.html.
I have cut more than a cord of Osage Orange and one 32 bullet that I didn’t see till it was done.
I have cut the pieces down to about 2 inches to make cutting boards. The blade still cuts like new. I would highly recommend their blade.
Craftsman on the lake
2799 posts in 3524 days
#12 posted 05-13-2014 01:16 AM
I don’t know about the band saw but I know that one in a sabre saw will cut really well and last a long time.
View woodchuckerNJ's profile
woodchuckerNJ
1285 posts in 1720 days
#13 posted 05-13-2014 01:29 AM
Andy I use the Timberwolf, didn’t know it was bimetal, are you sure?
I just went to the website, nothing there about bimetal.
-- Jeff NJ
gfadvm
#14 posted 05-13-2014 01:55 AM
Jeff, I called their 800 number when I got mine as it wasn’t in their catalog. I think Horizontal Mike is using the same blade on his BS.
It had better be bimetal for what it cost!
