What is a good clamp for a super thin panel glue-up?
« back to Joinery forum
Forum topic by HarveyDunn posted 05-12-2014 12:19 AM 1020 views 0 times favorited 4 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1817 days
05-12-2014 12:19 AM
I’m making a very thin panel out of numerous strips of wood. Final dimensions will be around 1/8” x 6” x 9”. It isn’t really a “panel” – it is going to be a piece of inlay. But “panel” seems like the easiest way to describe it.
I think I’ll probably do it in two batches, then glue those two together to get my final size.
Obviously, those 1/8” high edges are awfully small. What is a good clamp to use for something like this? Would a normal 12” parallel clamp be appropriate? I’m worried about the pieces not staying flat – I think the problem is called “racking”. I’ve left myself plenty of excess for jointing the face to get it flat. Even so, I would like to keep it as flat as possible in the clamp.
View Loren's profile
10477 posts in 3734 days
#1 posted 05-12-2014 12:30 AM
See the little wedges?
Use wax paper top and bottom. You can only see it on top here.
source: http://liutaiomottola.com/construction/Top.htm#mozTocId254934
View NiteWalker's profile
NiteWalker
2737 posts in 2663 days
#2 posted 05-12-2014 02:43 AM
Regular clamps with cauls, some some weight on the joint to prevent buckling.
View mantwi's profile
mantwi
312 posts in 1982 days
#3 posted 05-12-2014 02:50 AM
I’m with Loren on this. There’s a reason why luthiers use the wedge clamping method, it works very well. If it ain’t broke don’t fix it.
HarveyDunn
#4 posted 05-12-2014 04:02 AM
That is fascinating, thanks!
