router table insert fitment?
Forum topic by scribble posted 05-11-2014 09:27 PM 1179 views 0 times favorited 4 replies Add to Favorites Watch
View scribble's profile
scribble
204 posts in 2439 days
05-11-2014 09:27 PM
Topic tags/keywords: router jig
I found a piece of 1-1/4” thick countertop that was half mdf and have particle board with laminate on top to use as a router table. I did the method of making a scrap surround for the router to ride on when cutting out the recesse for the plate. I had the plate firmly surrounded when I removed it but when I cut the opening it seems to have gotten about 1/16” larger then then plate and is sloppy and can move around.
I am looking for any suggestions other than finding a new piece if possible.
Thanks for any help.
This group is great with helping people like me.
P.S. I know I should have practiced on a scrap piece first.
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
View JayBarnes's profile
JayBarnes
32 posts in 1825 days
#1 posted 05-11-2014 11:47 PM
Maybe wrap some masking tape around the edge of the plate then trim it flush with a razor. It should take up that 1/16’’ with just a couple wraps.
Jay
scribble
#2 posted 05-12-2014 09:05 PM
I appreciate your info. I tried it last night and that worked well. I am just a little worried about taking it in and out for bit changes and height adjustments.
I was thinking of maybe getting some type of epoxy and adding wax or a mold release to the plate then install the plate and add the resin to fill the void. I haven’t figured what resin to use to accomplish this though.
View ChefHDAN's profile
ChefHDAN
1230 posts in 3088 days
#3 posted 05-12-2014 09:32 PM
? Maybe some of the iron on edge banding, would hold up better than tape.. What router plate are you using, maybe upgrade to a slightly larger plate and recut
scribble
#4 posted 05-12-2014 09:37 PM
I am using a Rockler unit currently. Still not supper psyched about my router as it has to be the worst thing for adjusting depth. I may just say to heck with the current router and exchange the plate for one that fits a different brand of router.
