Lets turn that drill press into a pro buffing station..transformers!!!!
Forum topic by XBIGJIMX posted 05-11-2014 02:48 AM 3802 views 0 times favorited 5 replies Add to Favorites Watch
View XBIGJIMX's profile
XBIGJIMX
17 posts in 1731 days
05-11-2014 02:48 AM
Topic tags/keywords: drill press finishing
So anyway I have this Craftsman Drill press I was given, but I already had a floor drill press. So i posted it on Craigs list but after a month no takers what to do with it. Well I was half asleep and the thought popped in my head ..”Hey why not make it the buffing station you need”. So I said well that a damn fine idea…..
Here is the starting point.
So the only thing I bought was the wheels and this from Grizzly
After pulling it apart and tossing the extra parts I was left with the motor , pulleys, belt, and stand.
So i started off adding some extensions so I would have some clearance from the stand so I don’t accidentally bump into what ever i was buffing. So I grabbed some scrap Cherry and Maple. I cut em to the size needed and angled the edges with a hand plane.
Now I was really interested int he pulleys because I wanted the ability to adjust speed. Cause when doing finishing slow is always good. Now the first issue was the I.D. was to small to fit the arbor. So I am to cheap to buy the correct size so lets mod this sucker out. To the Lathe! So I bored it out to fit and then drilled out and tapped 3 set screws in the first hub.
Next Plugged the countersunk screws with Walnut and added a few coats of Tung Oil. And made a box for the switch out of maple and wired that.
Now with everything bolted in. I added the wheels and made some washers/stiffeners out of some end grain cutting board scraps. And boom one professional buffing machine with adjustable speeds
5 replies so far
View Kaleb the Swede's profile
Kaleb the Swede
1835 posts in 1998 days
#1 posted 05-11-2014 02:57 AM
That is really cool. really good thinking
-- Just trying to build something beautiful
View ,'s profile
2387 posts in 3576 days
#2 posted 05-11-2014 03:33 AM
Very nice project. Curious what u will use a buffing stain for.
XBIGJIMX
#3 posted 05-11-2014 03:37 AM
Polishing out Guitars. Its so much easier to move the guitar then the hand buffer
View Jim Finn's profile
Jim Finn
2658 posts in 2951 days
#4 posted 05-11-2014 01:25 PM
Clever idea and good job!
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Rick's profile
Rick
9753 posts in 3062 days
#5 posted 05-12-2014 06:13 AM
Very COOL Idea!
-- LIFE is what happens when you're planning on doing Other Things!
