Forum topic by jscore08 | posted 05-09-2014 06:46 PM | 18475 views | 1 time favorited | 6 replies | ![]() |
Topic tags/keywords: cedar milling joining modern tip question miter saw bandsaw clamp tablesaw I am having trouble determining the angles of to make x legs for a wooden table base. I am using 4×4 cedar pieces and need to make x legs that are 37.5 inches tall and the top can be a maximum of 24 inches wide from edge to edge. I wondered if anyone has a formula or a way to determine what the top and bottom angles are so that the wood legs lock in to be those specs previously stated. My friend made these legs previously (in the picture) but the height and width were different. Any help or direction would be greatly appreciated. |
#1 posted 05-09-2014 07:36 PM |
I would draw out a box 24 inches wide by 37.5 tall. Then take your 4×4 and lay it in there with the outsides of the stick touching opposing corners of the box and trace the stick of wood. Now use a protractor or just put tick marks on the 4×4 where it runs past the out side of the box and cut that angle. Probably a way more scientific to do it but whatever works. |
#2 posted 05-10-2014 04:41 AM |
Like dhazleton says, you can draw it out on paper then measure the angle. You could even draw it exactly 1/4 scale on a sheet of copy paper. The angle will remain the same. Cutting 1” wide paper strips to represent the legs for layout purposes would likely help, similar to what dhazleton suggests, If you don’t trust measuring the angle, you could take your drawing to the cedar pieces and transfer the angle directly to the wood. |
#3 posted 05-10-2014 06:24 AM |
One thing I’ve learned in my many years of doing carpentry work is to always chose direct measurements over calculating, if possible. Ditto what dhazelton and Yonak say… lay it out on paper and measure your angles from that. -- You can collect dust or you can make dust. I choose to make it. |
#4 posted 05-10-2014 11:53 AM |
I agree with the others, using direct measurements is always best. But if you really, really want to do this the hard way, Wikipedia has the geometry and math equations I’m half asleep and I probably did this wrong, but I come up with these numbers - Since each leg half forms a right triangle to the floor:. Since an X is two triangles that form a rectangle you also can use isosceles triangle math: Since you are trying to create a 57.38 degree angle to the floor, the wood will have to be cut as the complementary angle of 90 – 57.38 = 32.62 degrees. Note it’s not quite that easy. :) When it comes to making the notches for cross over lap joints, you need the exact wood width, and more math to find the beginning and end points. But this is another case where it will be much easier to just lay the pieces on top of each other in the prescribed rectangle on paper and physically mark it. Even if I wanted to make this piece, and had the proper angle numbers; I would still make a paper or cardboard rectangle template and use it to verify the calculated angle values. Even putting caulk lines the concrete floor will work if you don’t have paper. Always measure twice and cut once. Best of luck. -- I'm an engineer not a woodworker, but I can randomly find useful tools and furniture inside a pile of lumber! |
#5 posted 05-12-2014 05:04 PM |
Thanks everyone for the help. I will try it out today and hopefully I can figure it out. Much appreciated!! |
#6 posted 05-12-2014 05:17 PM |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2103 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4900 |
6691 |
28038 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6224 |
1387 |
Focus on the Workspace
2153 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2199 |
Coffee Lounge
8842 |
