Wood X legs angle help please!!!
Forum topic by jscore08 posted 05-09-2014 06:46 PM 1233 views 1 time favorited 14 replies Add to Favorites Watch
View jscore08's profile
jscore08
4 posts in 1446 days
05-09-2014 06:46 PM
Topic tags/keywords: cedar milling joining modern tip question miter saw bandsaw clamp tablesaw
I am having trouble determining the angles of to make x legs for a wooden table base. I am using 4×4 cedar pieces and need to make x legs that are 37.5 inches tall and the top can be a maximum of 24 inches wide from edge to edge. I wondered if anyone has a formula or a way to determine what the top and bottom angles are so that the wood legs lock in to be those specs previously stated. My friend made these legs previously (in the picture) but the height and width were different. Any help or direction would be greatly appreciated.
14 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3680 days
#1 posted 05-09-2014 11:27 PM
To do it math-free create some full size templates and lay ‘em out to fit your specs. Once you’ve got them laid out mark your intersections on the templates and off you go.
View Woodknack's profile
Woodknack
11485 posts in 2348 days
#2 posted 05-09-2014 11:34 PM
There was a thread about this a week or so ago and the gist is that the math is deceptively complicated. You are better off making a full size pattern as Mark suggests, drawing and measuring the angles, or lay them out using the materials and measuring the angles with a bevel gauge.
View oldnovice's profile
oldnovice
6773 posts in 3335 days
#3 posted 05-10-2014 01:00 AM
Ditto on what Rick said!
View Rob's profile
Rob
704 posts in 3039 days
#4 posted 05-10-2014 01:17 AM
The math isn’t that difficult if you remember some basic trig (SOHCAHTOA) or the Pythagorean theorem (e.g., a 3-4-5 triangle), but personally I’d just whip it up in Sketchup and measure the angle with the protractor tool if I didn’t feel like flexing my math muscles.
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1602 days
#5 posted 05-10-2014 01:19 AM
Do the math…
But if you are too lazy or don’t know how.
Get some help by sketchup. Do the diagram in sketchup.
Then you have the dimensions.
BTW it’s
Asquared + B squared=c squared
you know A and B
You know the height, you now the width, the hypotenuse is the leg
-- Jeff NJ
woodchuckerNJ
#6 posted 05-10-2014 01:43 AM
So I created a 1.5 ” leg
I don’t know why sketchup and calc don’t agree.
but I’ll let you work it out.
edit: ok, I know why the math doesn’t match. Because the math is based on a line, the sketchup is based on 1.5” leg
So 24-1.5 squared matches
-- Jeff NJ
Woodknack
#7 posted 05-10-2014 03:20 AM
Exactly, it’s more complicated than simple Pythagoras.
The angle for 4” wide stock will be 55° (rounded). If it’s really 3.5” stock then the angle will be different.
View Buckethead's profile
Buckethead
3194 posts in 1836 days
#8 posted 05-10-2014 03:46 AM
Thickness matters. You need to know the rate of the top/bottom cut. (Length of the cut). Not knowing angles means it’s more difficult to know the rate of the cut. You need to figure the 37” rise, (a constant because we’ve seen in the photo that the top and bottom cut are parallel to the floor and each other) and the 24” width MINUS the rate of the cut. (Once, not twice. Then you are effectively working the center of the board, and the angles of the theoretical centerline are the same as the edge). But wait…. There’s more.
We only figured the top and bottom cuts…. Right? What about the angles at the intersection? Subtract from 90? Nope.
Multiply times 2 then subtract from 180.
-- Support woodworking hand models. Buy me a sawstop.
Woodknack
#9 posted 05-10-2014 09:45 PM
I’ve never heard the term “rate of cut” used in that context, is that a carpentry phrase? I googled the phrase and the only usage I could find meant feed rate or blade speed. Not arguing (can’t always tell on the internet), just curious.
Buckethead
#10 posted 05-10-2014 09:47 PM
It is just what I have heard it called in the framing world here in Florida. It may be absolute bunk. Southern professional carpentry is often lacking in tradition and terminology.
View kdc68's profile
kdc68
2649 posts in 2244 days
#11 posted 05-10-2014 09:59 PM
Rick M.
v
Bucketheads first sentence answers your question….
Thickness matters. You need to know the rate of the top/bottom cut. (Length of the cut)......
Edit: nevermind he posted as I was cutting and pasting…lol
-- Measure "at least" twice and cut once
Woodknack
#12 posted 05-11-2014 01:42 AM
@kdc, “Bucketheads first sentence answers your question….”
It would if my question had been, ‘what does it mean;’ but that wasn’t my question. I was just curious if it was a term from some particular industry.
kdc68
#13 posted 05-11-2014 11:38 AM
Rick M.
Gotcha….my apologies…
Woodknack
#14 posted 05-11-2014 07:27 PM
Think nothing of it. Hope your weekend is full of woodworking!
