I Dood It - Looking for a Build Plan
Forum topic by Smitty_Cabinetshop posted 05-09-2014 01:25 PM 2921 views 0 times favorited 15 replies Add to Favorites Watch
Smitty_Cabinetshop
15348 posts in 2615 days
05-09-2014 01:25 PM
If you know what this stand/carnival game is, maybe you can help. We need to build one, and quick, but my searchfu on the interwebz turns up nothing. Looking for plans, can you help?
Sorry for lack of detail for those who don’t know, but I’ve not actually seen or played it… I’m told it’s an involved build (?); doesn’t look too bad, so I must be missing something. Here are the only pics I have:
Thanks!
15 replies so far
View chrisstef's profile
chrisstef
17381 posts in 3003 days
#1 posted 05-09-2014 01:46 PM
Any idea as to the premise of the game Smitty?
Smitty_Cabinetshop
#2 posted 05-09-2014 01:48 PM
It’s all about getting some kind of ‘five in a row’, don’t know more than that. That insert would certainly be a bought piece, you’d think.
chrisstef
#3 posted 05-09-2014 01:54 PM
Its kind of like skeeball mixed with bingo?
The insert looks like a stepped series of forstner bit holes. One larger ring on the outside with an inner, smaller, ring? But then there appears to be square tapers. CNC’d id imagine.
chrisstef
#4 posted 05-09-2014 01:57 PM
Got it .. Ball Bingo is the name. Appears to be a few iterations of it online
chrisstef
#5 posted 05-09-2014 01:59 PM
http://funservicesbayarea.com/wp-content/uploads/ballbingo.pdf
PDF to the rules.
Smitty_Cabinetshop
#6 posted 05-09-2014 02:06 PM
It’s all about that insert. Not a muffin pan, plastic of sorts. Has to be a bought item, right? From where?
chrisstef
#7 posted 05-09-2014 02:06 PM
The box measure 20” x 20” x 20” and ive seen it using ping pong balls. Id figure to drill out the holes with a forstner bit a little smaller in diameter than the ball. The diameter of a ping pong ball is 40mm or 1.57”. You might get away with 1.5” forstner?
Search fu level = Wizard.
That insert may be tough to find Google image search shows a lot of homemade ones out of plywood. Let me see if I can obtain grand wizard status.
View woodchuckerNJ's profile
woodchuckerNJ
1274 posts in 1630 days
#8 posted 05-09-2014 02:07 PM
So nothing complicated about anything but the insert.
Everything is basic except that.
The insert you would need to make a router template that allows you to lower the router and raise it back as you are moving. Not easy. There is a router carving tool like that. But you would have to make your own template.
Someone with a CNC could do that quickly.
The only other way I could think of making this quickly, with little fuss, is to build a grid, then glue in the angled pieces. Cut long wedges, then miter them up, glue them in the grid, then drill the holes.
So to build the wedges, take a long piece of wood and on a table saw or band saw cut the wedge length wise.
Then use a band saw to cut the miters (safest).
-- Jeff NJ
Smitty_Cabinetshop
#9 posted 05-09-2014 02:10 PM
Jeff, I like the way you think! That is a very solid approach.
View Don W's profile
Don W
18711 posts in 2564 days
#10 posted 05-09-2014 03:10 PM
for the center piece, take a piece of 3/4 stock, drill the holes all the way threw, run a low angel chamfer bit with a bearing around each hole to give the slope, then glue a bottom and paint.
View Brit's profile
Brit
7376 posts in 2839 days
#11 posted 05-10-2014 12:52 AM
I agree with Don Smitty. Don’t get too hung up on the exact shape of the plastic tray in the photo. You need a 5×5 grid such that when you throw the balls at it from a distance of 5 feet, each ball will settle in a hole. Depending on the diameter of the balls you’ll be using, think things like:
pool ball trays
seed trays
egg trays
ice cube trays
golf ball trays, cake ball trays, etc., etc.
Just trying to think outside the box Smitty
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View Buckethead's profile
Buckethead
3194 posts in 1865 days
#12 posted 05-10-2014 01:01 AM
I think Jeff is on to it. Wedges. He already described. Assemble them properly oriented on a quick and dirty perimeter/backing jig (like a picture frame with a plywood back). Maybe got glue. Then after drilling the holes into the centers of the assembled wedges, remove them, then wood glue them to an un damaged piece of 1/4 (or whatevs) ply, MDF, etc.
A hole saw might be a better bet for cutting the circles. It is a bit rougher, but maybe the point of the Forster bit will be hindered from properly keeping you on center due to the sloped sides.
-- Support woodworking hand models. Buy me a sawstop.
View GerryB's profile
GerryB
69 posts in 2578 days
#13 posted 05-10-2014 03:51 AM
The name of the game is Fascination. My wife worked at the Olympic Fascination parlor on the boardwalk at Wildwood, New Jersey. The balls she remembers are about handball size. Wilkipedia explains pretty well. http://en.wikipedia.org/wiki/Fascination_%28game%29
-- The pursuit of excellence is gratifying and healthy. The pursuit of perfection is frustrating, neurotic, and a terrible waste of time. Edwin Bliss
Buckethead
#14 posted 05-10-2014 04:06 AM
Hot glue in my post instead of got glue.
Smitty_Cabinetshop
#15 posted 05-10-2014 06:19 PM
Gerry, thanks very much for that!!!
