router bits
Forum topic by capttom posted 05-09-2014 02:10 AM 1039 views 0 times favorited 11 replies Add to Favorites Watch
View capttom's profile
capttom
2 posts in 1442 days
05-09-2014 02:10 AM
Topic tags/keywords: question
First time on this site,so if this has been covered,sorry about that. I finished making my router table and reached for my router bits,realized i need to upgrade. looking for thoughts on name brand[bosch freud] vs no name. Are they worth the extra cost,or is there not much difference? Thanks, looking forward to learning and seeing great woodwork.
11 replies so far
View kdc68's profile
kdc68
2649 posts in 2240 days
#1 posted 05-09-2014 02:15 AM
Short answer yes. For example, buying a Whiteside (premium) stays sharper longer and nets the best results. Buy the best you can afford
-- Measure "at least" twice and cut once
View Fish22's profile
Fish22
83 posts in 3076 days
#2 posted 05-09-2014 02:28 AM
I bought a set from MLCS Woodworking and have been happy with them, but I agree with kdc, buy the best you can afford.
-- Bryan, South River, NJ
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1597 days
#3 posted 05-09-2014 02:29 AM
Short answer is NO.
It’s complicated.
For most stuff, I buy woodline.
When I have really critical stuff, I will spend more on premium, whiteside, CMT’s.
But I find there is not much diff.
I did buy Jesada a premium… spent over 400 on bits, and only 2 out of many were good. There were out of balance carbides (some stuck out more than the other), some did’nt line up with the bearing on flush trim,
Way too many issues. I have a raised panel set that the coping is not matched on. So you don’t always get what you pay for. Jesada is dead to me.
You can do well with lower cost bits. They work real well. Just stick with the few good offbrands
Woodline, MLCS, a few others.
For the finest work, the most knarly grain in wood, go for the whiteside. But understand you can buy 2 bits for the price of a whiteside, sometimes 3. And I don’t find the whiteside 3x better. Better yes, but not 3 times.
If you want to buy American, buy Whiteside.
-- Jeff NJ
View NiteWalker's profile
NiteWalker
2736 posts in 2540 days
#4 posted 05-09-2014 02:35 AM
If you have a cheaper set or cheaper bits, use those. Whatever you end up using the most, replace with whiteside router bits.
Hartville tool and holbren are both excellent sources for whitesides.
CMT, freud, amana and infinity all make good bits too, but whitesides are my favorites. They hold up and they’re not too expensive.
I use MLCS bits on occasion too, and they’re ok, but not even close to whitesides.
capttom
#5 posted 05-09-2014 02:51 AM
thanks for your comments,I have always bought the best I could afford, I did buy a whitside half inch up spiral for box joints and mortise pockets but a whole set is out of my comfort zone. I think
i already knew what the responses would be, I guess I just wanted to hear it.
View pintodeluxe's profile
pintodeluxe
5620 posts in 2776 days
#6 posted 05-09-2014 03:15 AM
I don’t find the brand name bits any more expensive, or at least not by much. I have had good luck with Rockler, Freud, and Whiteside brand bits. The Bosch bits don’t seem to stay sharp as long.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3676 days
#7 posted 05-09-2014 05:17 AM
I’ve become a lot more cautious about buying ‘sets’ of bits. It seems that I only use a select few from that set and, as mentioned above, I would upgrade individual bits as the less expensive ones broke or wear out. It is nice to have the set to experiment with and it has helped me get a better idea of which bits I will actually use. So on the learning side the sets are worth it IMHO but economically I think it’s a wash.
View knotscott's profile
knotscott
7980 posts in 3339 days
#8 posted 05-09-2014 09:26 AM
I’m in favor of spending the router bit budget wisely….that can include some highend bits or a small set of “decent quality” bits, depending on the application of what you’re building. A swing set might benefit from some rounded edges, but it might not matter if the edges are perfect. On the opposite end of the spectrum, a family heirloom caliber formal dining room table should have the best edge you can get IMO. I’m not generally in favor of spending big bucks for lots of low quality bits. Off-name bits are more likely to cause injury and perform poorly, so I strongly suggest avoiding them and sticking with at least a decent level brand.
Buying Router Bits
View Monte Pittman's profile
Monte Pittman
28903 posts in 2301 days
#9 posted 05-09-2014 09:42 AM
Cheap bits dull quickly. Then you will replace them frequently.
Welcome to Lumberjocks
-- Mother Nature created it, I just assemble it.
View bowedcurly's profile
bowedcurly
519 posts in 1692 days
#10 posted 05-09-2014 10:33 AM
WS is s smooth running bit it can make a junky router look good, I mean made my junky router cut like a dream. They are balanced better and run and cut very smooth, try one you will like it.
-- Staining killed the wood<<<<<>>>>>Dyeing gave it life
NiteWalker
#11 posted 05-09-2014 10:44 AM
Scott, great article on router bits, though I would put cmt right up there with whiteside, freud, etc.
I have some cmt bits several years old that still cut cleanly and smoothly. :-)
