How fast should I be able to resaw?
Forum topic by toddbeaulieu posted 05-09-2014 01:39 AM 1036 views 0 times favorited 9 replies Add to Favorites Watch
View toddbeaulieu's profile
toddbeaulieu
814 posts in 2972 days
05-09-2014 01:39 AM
Hello, I’ve been resawing a lot of 3×5 white cedar recently. It’s very old …. DRY.
I have a highland woodworking wood slicer 3/4” x 3-4 TPI blade.
In my unprofessional opinion it’s just not cutting fast enough. The blade is fairly new. I’d estimate it takes me 3 minutes to rip an 8 footer.
Is that normal?
I thought I wanted a 1-2 TPI blade and wider but I discovered that highland doesn’t go wider or lower TPI which made me question my thinking. My saw is an OLD Grizzly 18”. Forget the HP. Nothing crazy.
Would appreciate your thoughts!
9 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2658 days
#1 posted 05-09-2014 01:52 AM
todd, That cedar should be pretty soft and easy to saw. I put a 1”, 1 TPI Timberwolf band on my 17” Grizzly and it will resaw 10” Jatoba (really hard) as fast as I can feed it! It’s almost scary as there is almost no pushing required. I also have a 2-3 variable TPI 3/4” bimetallic band from Timberwolf that saws almost as fast and leaves an amazing finish. Timberwolf is really good about advising you as to the best blade for your application. Call their 800 number and ask questions.
View crank49's profile
crank49
4030 posts in 2939 days
#2 posted 05-09-2014 02:01 PM
Wood slicer from Highland is a good blade, but with an 18” saw I’d go to a 1” blade with lower tooth count as gfadvm suggested.
Also, blades get dull pretty fast sometimes; depending on what they have been cutting more than how much. I have dulled a new blade on one board. It’s possible.
toddbeaulieu
#3 posted 05-09-2014 02:05 PM
Thanks guys.
I really want to experiment with a wider blade. I’ll order one.
I think you’re probably right about mine getting dull. I wouldn’t think my cedar would have much tension in it, but it was actually binding. It got to the point where I had to split it on the output side or it would bind the blade and stop it from spinning. Maybe that’s just because the blade got dull?
Do you sharpen your own blades?
gfadvm
#4 posted 05-09-2014 02:06 PM
I can’t figure out why the blades on my sawmill last SO much longer than the ones on my bandsaw. And when they get dull, I send them in and they get resharpened/reset for $7 each! And they cost less than half what the bandsaw blades cost!
View Buckethead's profile
Buckethead
3194 posts in 1837 days
#5 posted 05-09-2014 02:23 PM
I wonder if more horsepower actually eases wear on blades.
Any thoughts?
-- Support woodworking hand models. Buy me a sawstop.
View HorizontalMike's profile
HorizontalMike
7749 posts in 2882 days
#6 posted 05-09-2014 02:28 PM
I recently did a bunch of resawing and could tell on exactly what “cut” my lower thrust bearing locked up (failed). When the thrust bearing failed, the feed rate dropped to probably 25% of what it was. The cut was still straight, but had to push much harder without any other feedback from my 14in Rikon 10-325 BS.
Just a thought. Bearings are cheap, if you shop wisely. And they are very easy to replace.
View Ocelot's profile
Ocelot
1960 posts in 2606 days
#7 posted 05-09-2014 02:28 PM
Here’s a link to Woodgears guy – who sharpens his own.
http://woodgears.ca/bandsaw/sharpening.html
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1602 days
#8 posted 05-09-2014 02:48 PM
I have to ask, have you been cutting wood with bark on it?
Bark dulls blades fast. I used to saw raw logs w/o removing the bark.
I was never happy.
On a chance I started taking the bark off. I was now able to saw longer, and faster.
I use the same blade for resawing. And I noticed a huge difference in resawing. So I was killing my blades when I was sawing logs.
-- Jeff NJ
gfadvm
#9 posted 05-09-2014 03:48 PM
Jeff, Almost all the logs I saw on the sawmill have the bark on. Doesn’t seem to be a problem unless it has dirt/mud/gravel in it.
